Flat Roof - Do I Need To Tear Down The Old? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-30-2013, 08:06 PM   #1
Flat roof - do i need to tear down the old?
I'm looking to re-do my flat roof in a semi detached home in Toronto; one of the contractors said that I can put it on top of the existing one (it looks like it has 2 roof already). This would save me 50% on price.
Any advise on whether it's worth tearing down the current one?
Thanks!
JK
Jkotowski is offline   Reply With Quote
Old 06-30-2013, 10:11 PM   #2
Metal Roofing
Rewards Points: 600
That is dependant on if it is one or two layers atm. You can't go over two existing layers. You should tear off all existing layers.
AndyWRS is offline   Reply With Quote
Old 06-30-2013, 10:40 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,296
What are the two previous layers?
Pictures?
What is he proposing in terms of the new roof?
Old 07-01-2013, 08:06 AM   #4
Rewards Points: 652
Going by Toronto, is he proposing to just torch a new cap sheet down over the existing, without any sort of recovery board or anything? I see this a lot.
PatChap is offline   Reply With Quote
Old 07-01-2013, 12:31 PM   #5
I am not sure how the existing roof has been laid down.
He said he would two two layers with torch down.
My two concerns are added weight to the roof and durability of the new roof - hence looking for advice.
Thx
Jk
Old 07-01-2013, 02:51 PM   #6
Roofmaster
Rewards Points: 2,210
Tear it off down to the structural deck. This gives you a chance to look at and repair any problems in the deck. You generally do not want to attach a new roof to a failed existing roof. There are exceptions, but it does not sound like you have one of them.
I would personally never use a torch applied product on a wood framed home. as it is very possible to burn down your home.
If you are working with a real roofer he will have a kettle to heat asphalt, and he can install an SBS mopped down Mod bit over a glass base sheet or you can have them use cold process adhesive. Always apply Mod bit in two plies.
You can also use a real single ply like EPDM, or PVC.
The Following 2 Users Say Thank You to jagans For This Useful Post:
Jkotowski (07-01-2013), Windows on Wash (07-01-2013)
Tags
flat roof
Flat Roof - probably not DIY for me mymrbig Roofing/Siding 13 02-26-2013 05:31 PM
Questions about flat roof repair-repalcement crhilton Roofing/Siding 5 08-21-2010 01:25 AM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 12:12 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 05:48 PM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
