Flat Roof Construction- Insulation - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-02-2007, 08:49 PM   #16
Hello EricC,
You could try using http://www.fomo.com/. We have used this from time to time. There is a company here that all they do is poly spray foam insullation. You can fill your joist cavity with this stuff and it also acts as a VB, plus you will not have the extra height of the build up.
Hope this helps,
Keith
roofboy is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
Flat Roof Suggestion gladiator Roofing/Siding 3 09-14-2005 03:31 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
