Flat Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-23-2006, 11:36 AM   #1
flat roof
is it normal to have pools of water on the end of the slope of
a new felt flat roof.
william is offline   Reply With Quote
Old 08-23-2006, 02:42 PM   #2
are there any drains on the flat roof?
redline is offline   Reply With Quote
Old 08-23-2006, 07:28 PM   #3
Commercial Roofing
AaronB's Avatar
Felt and what? What does the edge detail look like?
Sometimes if the roof pitch doesnt overtake the edge detail build up, you may have a small "birdbath" at the roof edge.
I am going to assume since the roof is flat, and you say "felt" that it is a tar and felt roof? Like a BUR? Some come with gravel, some smooth surfaced, some with a mineral surfaced cap sheet.
In all of these cases, there should be a field membrane turned down over the roof edge, a perimeter metal on top of the roof field, and a cover strip configuration. The buildup of the multiple layers will raise the roof edge. If the roof pitch doesnt overcome this height, you will get a bath on the edge.
If it is gone within 72 hours, then almost all system mfg's consider this amount of water acceptable.
This is all speculation since I dont know your particular situation.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 08-24-2006, 10:08 AM   #4
Flat Roof
Thanks to Redline and AaronB for prompt replies.The roof does not have a drain, it was leaking so we have just had new felt roofing system.
The rain water appears to be retained about a foot from the drainage end, this slopes but obviously not enough. We have just had heavy rainfall which left pools of water at the lower end of the roof but the wind seems to be drying it out at the moment so may not be as much a problem as we thought.
Old 08-24-2006, 11:17 AM   #5
Commercial Flat Roofing
Well, accepted guideline for standing water on a low slope roof is 48-72 hrs.
There will some debate on this but, if the water is still there in any substantial amount after that amount of time, you may need to consider tapering the roof edge to improve drainage.
Talos4 is offline   Reply With Quote
Old 08-24-2006, 06:17 PM   #6
Commercial Roofing
AaronB's Avatar
Can you post a pic?
Old 09-10-2006, 09:57 PM   #7
Would need some pics to tell you whats going on
jshirah is offline   Reply With Quote
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 07:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 09:34 PM
