-   -   Flat metal roof seam issues.. (http://www.diychatroom.com/f9/flat-metal-roof-seam-issues-178312/)
backemin 04-28-2013 08:53 PM
Hello all, newbie here from WI. I rent a shop with a corrugated matal roof that was improperly installed. They put mesh on all the seams then coated the seams with some black stuff that has dried up and curled. The roof leaks in a few spots. The landlord said he'll work a deal with me if I take care of it myself. So, being it's not my building I'm looking for suggestions on how to deal with this mess so I can stay in the building a few more years with the existing roof. The panels are all in pretty good shape, no rust, just alot of seams that are pretty messed up with this dried, curled crap on them. Any suggestions on what i should put over this. If I scrape off all the loose stuff what should I put over the seams kowing that some of this stuff will still be there??
Thanks to all!!!
AndyWRS 04-28-2013 09:36 PM
Post a few pics so we can see exactly what your dealing with.
backemin 04-28-2013 09:52 PM
I new i should have taken some today...I'll get them tomorrow.......if its not raining.
THX!
Windows on Wash 04-29-2013 08:14 AM
+1 on pictures and plan on re-coating the whole thing.
While the entire roof may not need it, it is probably easier and will look more seamless that way.
tinner666 04-29-2013 10:30 AM
You need to loosen the panels and run a few beads of sealant between them, and not exposed. Re-screw the panels. This will break the capillary action of co-joined panels.
When calked on top, or just in the joint, movement breaks the seal within days and the caulk acts like a dam/diverter and literally shoots the water back up and into the seams.
backemin 04-29-2013 07:42 PM
3 Attachment(s)
Photos attached.....suggestions???
tinner666 04-29-2013 09:10 PM
We'll know more after you get all that mess cleaned off. Maybe scrape and power wash it off being careful NOT to direct any water into any joints.
jagans 04-29-2013 09:39 PM
Lightly heat with a modified torch and scrape off the loose crap, then power wash with 4000PSI, let dry then foam it with Sprayed Polyurethane Foam, and coat it with silicone The owner currently has a building he cannot rent, with a crap roof. Hopefully you can get him to understand this.
There is no cheap and dirty fix for something that has been screwed up like this. Whoever did it should be shot, or at least coated with roof cement and wrapped with fabric. :thumbup:
OldNBroken 04-29-2013 09:49 PM
Considering it's about the same climate as here, I doubt SPF is a good option in his region. Could look into a full elastomeric or acrylic coating but by the time that was done you probably could put a proper roof on it.
1985gt 04-30-2013 01:55 PM
Flute fill and 1/2 HD ISO and EPDM, If the structure is proper. Or, remove all of the panels, go to Menards/HD/Lowes order the length you need and re do the whole thing, only this time put the sealant between the laps. Looks a bit low slope to me.
If there is a solid structure under it I would go flute fill and 1/2 HD ISO and EPDM route.
I would not advise using spray foam. Spray foam does not still well to metal if there is not a solid substrate under the metal panels, after some times the two "roofs" will separate and will leave even a bigger mess. Plus it simply is not a good product, that or I have never been on one that looked/preformed well at all.
It's not likely a coating would stick well in the seam areas either with the mess that was left there. Coating it would have been an option before but now it would be a lot more prep work.
jagans 04-30-2013 11:10 PM
This is what is known as a crap lap through fastened metal roof. The exposed fasteners egg-hole after about 8 years and they leak. The laps are obviously already leaking. This roof appears to be very low slope. I still think foam would be a good approach, and I'm not sure why it would not be a good choice in an area that gets pretty cold in the winter, but we all have our reasons I guess. Foam would arrest the panel to panel thermal movement, and result in a seamless application.
The other option would be to put on a good metal roof like a Butler MR-24, but then you would need wind bracing, as your diaphragm would be gone. Re-Cover would also be an option with an MR-24 if it will take the weight, but most of these types of buildings are right at the tipping point engineering wise.
Coating will not work in my opinion.
one cut 05-02-2013 12:16 AM
It sounds like you have a real life slum lord on your hands.
backemin 05-02-2013 02:28 PM
Thanks to all that responded..Except "One Cut" ..You know not of what you speak.
OldNBroken 05-02-2013 03:28 PM
:laughing: :laughing: :laughing:
I know what you mean, My situation is similar to yours. Exact same type of bldg but I have a very good give-and-take relationship with the owner. Mine, unlike yours, has been and is repaired properly when the need arises.
