Flat Garage Roof--what To Use? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-22-2009, 01:31 PM   #1
flat garage roof--what to use?
My garage roof is cracked and leaking--some kind of rubber.
Menards has 5 gallon pails white sealbest for $59 or aluminized by roofworks for 39?
Any recommendations?
I don't plan to have this garage for long, so i don't want to spend a lot of money.
it's about 500 sf. it would take two 5 gallon pails
ElvisPresley is offline   Reply With Quote
Old 08-24-2009, 03:50 PM   #2
Commercial Roofing
AaronB's Avatar
None of it will work. You may need a new roof.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 10:31 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 08:41 AM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 06:56 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
