Flat Concrete Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-02-2012, 04:20 PM   #1
Flat concrete roof
I, i have bought a house! Finally!!! There has been a recent extension built on to the back of the house, single story) ther is a flat concrete roof wher the extension is been built onto and is now a storage cupboard, im having problems with damp coming through the concrete, irs beens flashed, sealed with tar and now ive put felt on it with felt adesive! Still damp!!! Any ideas??
Ramsay19 is offline   Reply With Quote
Old 01-02-2012, 09:19 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,582
Where is the home located? Are you sure it is coming from the top down or is it coming from the bottom up?
Old 01-02-2012, 09:26 PM   #3
Rewards Points: 14,312
Two things wrong, it's a flat roof, and it's concrete.
With any flat roof it's not a matter of will it leak it's when will it leak.
Did you get a home inspection before buying this?
Call some commecial roofing companys they can lay a one piece rubber membrane EPDM down and stop all the leaks.
Old 01-03-2012, 09:03 AM   #4
What about a neoprene rubber lining? That should work
Old 01-03-2012, 09:09 AM   #5
http://www.firestonebpco.com/roofing/epdm/
And this is not a DIY job if you do not want it to leak, your not going to have the tools or the know how.
New Rubber Flat Roof w Ponding Problems Shifter Roofing/Siding 8 10-20-2010 10:58 AM
Flat roof related questions christy123 Roofing/Siding 8 12-09-2008 11:30 PM
Townhouse flat roof - Neighbor's contractor place huge weight of shingles on our roof DIYInCT Roofing/Siding 2 11-23-2008 10:31 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 06:01 PM
