Flat Built-up Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-28-2008, 06:11 PM   #16
I just wanted to respond about that biew point from the manufacturing facility, due to the "Inside" information about the watering down of the asphalts in shingle products currently.
How much more of this can go on, before a 30 year roof only lasts 3 months instead?
Ed
Ed the Roofer is offline   Reply With Quote
Old 03-28-2008, 09:37 PM   #17
the roofing god's Avatar
Send a message via MSN to the roofing god
another reason single ply is the new king,maintenance areas should be budgeted to be covered with rubber walkpads in maintenance areas to prevent damage,unfortunately too often it all breaks down to the almighty dollar
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 03-29-2008, 12:41 AM   #18
For a properly trained crew who has the right equipment, I would still personally prefer a Coal Tar Pitch roof.
I installed many, many brands of single plys, and the main defect that occurred from one brand to another, was the maintenance and actual working staff going up on the roof creating minor damage.
But, a "Minor" slice in a single ply membrane is a 100% intrusion of water.
If the facility that is getting attended to had a dutiful, conscientious maintenance supervisor AND did not allow any other contractor or building employee up on the roof unsupervised, during the entire time that they needed to be up there, then the single ply roofs would be a much more resiliant system.
I love putting them down and also, they are much easier to install and to patch, in the event that a patch is needed though.
Ed
Modified bitumen vs 60 mil EPDM membrane Flat Roof doingygirl Roofing/Siding 11 01-07-2008 09:41 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 07:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
