Flashings - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-08-2009, 10:33 PM   #1
Flashings
How does rubber compare to steel / aluminum? Is it even close? Have a roofer singing its praises.
reeses is offline   Reply With Quote
Old 04-09-2009, 12:43 AM   #2
747
registered
747's Avatar
Rewards Points: 534
It depends on the area being flashed. Maybe he is just saying that because flashing seperates the men from the boys on roofing. Laying a shingle is easy flashing is a art. Actually it should have both. Grace ice and water flashing over that. But like i said i'm not sure what the area looks like or what rubber membrane he is talking about.
747 is offline   Reply With Quote
Old 04-09-2009, 02:35 AM   #3
BIGRED
Rewards Points: 252
Rubber is OK for plumbing and or soil stacks. You should have tin or aluminum flashings for any type of combustion flue even if it's double or triple wall 'B' vent and they should all be caulked to the stack/vent and to the roofing.
Grampa Bud is offline   Reply With Quote
Old 04-09-2009, 09:54 AM   #4
Rewards Points: 392
Squirrels like to chew on rubber.
rustyjames is offline   Reply With Quote
Old 04-09-2009, 09:59 AM   #5
Rubber, aka, EPDM, is a functional product for flat roofs and should be used for where it was designed for, which is on flat roofs.
A properly done sheet metal flashing and counter-flashing installation has proven itself for generations with the test of time, but SMACNA and NRCA installation guidelines should be followed.
Ed
Ed the Roofer is offline   Reply With Quote
Flashing around Dormers? dbogey Roofing/Siding 6 04-23-2008 11:32 AM
Leaks around chimney after new roof was put on proofer Roofing/Siding 25 04-22-2008 01:31 AM
leak in chimney water comes threw brick Kdawg Roofing/Siding 51 02-08-2008 03:18 PM
when to replace a skylight & flashing question CindiChm Roofing/Siding 3 10-08-2007 09:18 AM
Need a Commercial Roofer for Baltimore City Low Slope Roof! Mphasemedia Roofing/Siding 4 12-26-2006 11:02 AM
