Flashing Uplifting... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-29-2013, 07:25 PM   #1
valcarmo72's Avatar
I have some flashing that appears to be uplifting. The aluminum seems to be in place. It seem as if the white laminate on the flashing is coming up. I was thinking of cutting the laminate off and painting it. I wonder if its because the sun beats the crap out of it all day long...not sure but any thoughts...
valcarmo72 is offline   Reply With Quote
Old 04-29-2013, 07:35 PM   #2
valcarmo72's Avatar
Oh its flashing that is under the siding and meets the shingles. It about 3 inches overlap on the shingles. Shingles are on an overhang that runs across the whole front of the house mid way.
Old 04-29-2013, 07:49 PM   #3
kwikfishron's Avatar
Rewards Points: 832
If it's aluminum coil stock flashing it sounds like electrolysis.
Pictures please.
kwikfishron is online now   Reply With Quote
Old 04-29-2013, 08:02 PM   #4
valcarmo72's Avatar
Oh man...I guess ill post a pic tomorrow. Dark out have get up on the ladder. Want to take close ups so I get good feedback. Till tomorrow. Thx for the reply.
Old 04-29-2013, 09:04 PM   #5
Roofmaster
Rewards Points: 2,210
DO you mean its an apron flashing on which the paint finish is separating from the metal? What do you mean Laminate? When I think of Laminate I think of Formica.
Old 04-29-2013, 09:10 PM   #6
valcarmo72's Avatar
Lol...sorry. yes your right the paint finish. But from 15 feet below it..it seems like the paint is coming up all in one piece. As if it were another piece of sheet metal glued to another...for lack of better terms...ill post a pic tomorrow. Appreciate the help.
Old 04-29-2013, 09:17 PM   #7
You could just tar shingles over the flashing
jsbuilders is offline   Reply With Quote
Old 04-29-2013, 09:22 PM   #8
valcarmo72's Avatar
I guess that would be a good idea.
Old 04-29-2013, 10:22 PM   #9
Doing This Way Too Long
Rewards Points: 532
Umm, not really
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
kwikfishron (04-30-2013)
Old 04-30-2013, 03:19 PM   #10
valcarmo72's Avatar
Obviously.
Old 04-30-2013, 03:53 PM   #11
Rewards Points: 532
Obviously.
We just hate ever hearing slathering asphalt or caulk is a fix for anything ever
Old 04-30-2013, 04:59 PM   #12
The tar is under the shingles, and its only use is to hold the shingle for cosmetic purposes.
According to the op the problem is cosmetic. So why not fix it with a commonly used and proven cosmetic practice.
Old 04-30-2013, 05:23 PM   #13
valcarmo72's Avatar
This first pic doesn't really show the uplift but u can see where the bare aluminum is shining in the sun.
This pic u can see where the siding meets the shingles and in between in the flashing or whatever u call it. Can u see where it is lifted? It to the left. U can't really see the j channel as u cam on the right because the white layer is coming up.
Old 04-30-2013, 07:19 PM   #14
valcarmo72's Avatar
Here's a better pic as the sun is going down so u can see the lifting.. thx everyone for the help.
Old 04-30-2013, 07:44 PM   #15
Rewards Points: 532
Can't really tell what is going on there. Normally that would just be a piece of bare or painted metal covering the transition from roof to wall. Hence the name roof-to-wall, or end wall or am sure others call it something else.
Is the part coming off rigid or does it flop around? Only thing I can think of possibly is the installers never took the protective film off before installing it. Can't really tell without seeing it close up, sorry. Unless that is a re-roof and what is sticking up is an old flashing that the new installers just went behind with their metal.
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 04-30-2012 11:42 PM
the very best materials for replacement chimney flashing are? DIherself Roofing/Siding 10 04-19-2012 08:22 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
