Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-09-2013, 07:10 PM   #1
Flashing suggestions please - rake fascia meets open valley
I am looking for suggestions on how to properly flash this exposed roof where the rake fascia meets an open valley flashing. Right below the bottom edge of the picture is eve spouting. This is builder work and I am concerned that water can freely blow into the roof. Thank you! (links/documentation/images are especially welcome)
Flashing suggestions please - rake fascia meets open valley-20130209_143128.jpg
jason.shaffer is offline   Reply With Quote
Old 02-09-2013, 07:13 PM   #2
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
I have always just trimmed the valley flashing along the line of the rake.
Then a little mastic between the flashing and the rake roof drip edge seems to do fine. no nails at that area.
Andy.
Residential Drafter/Designer
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
jason.shaffer (02-09-2013)
Old 02-10-2013, 04:49 PM   #3
"Nail-Bender"
They should have run the "apron" (wall to roof flashing) all the way under
the "W" valley, flashing.
I think I'm seeing bare, wood - between the fascia and the roof.
You can try and slide a piece of flashing, under the aluminum fascia -
over lapping the existing apron.
If you use any mastic/sealant -
Don't use "tar"/roof cement -
Use "Quad" or "Solar Seal".
They didn't use roof-edge.
rossfingal
rossfingal is offline   Reply With Quote
Design suggestions to avoid a dead valley benjamincall Building & Construction 19 01-12-2012 01:17 PM
Flashing Intersection of two Rake Walls project_guy Roofing 6 10-25-2011 01:50 PM
Why can't I find a good thatch rake or pine needle rake? carl1864 Landscaping & Lawn Care 5 06-05-2011 02:01 PM
Do I need flashing in the valley for woven shingles? tidal9 Roofing 3 06-06-2008 12:15 PM
Open valley flashing question steve1234 Roofing 2 10-01-2007 01:19 PM
