Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 12-20-2009, 04:50 PM   #16
MJW
flashing and stucco
Originally Posted by dmc@RCR View Post
a. Cut the nails from the inside with a sawzall and pull the flashing from the exterior. Not easy.
b. Cut the stucco off the roof a few inches, re flash, install wood trim in place of stucco.
If you're gonna do this, flash above the board also. It would be best to use something cedar or some type of PVC board, so you don't have to paint it every year.
MJW is offline   Reply With Quote
Old 12-21-2009, 06:32 AM   #17
Exterior Window Trim
Decoramould's Avatar
flashing and stucco
Obviously, your best option is to rip off whatever is currently there. It was very poorly designed/specified, and poorly installed as well. You can clearly see water on the inside, and since this is a "rainscreen" system, it's obviously failing.
For starters, I don't see what flashing at the bottom is going to do. Any water that gets behind has no weather barrier to run down and get diverted. Adding a flashing isn't going to fool anyone - and if the next home owner gets a half decent inspector there's no way they'll miss the mess that is that "cladding".
I also wouldn't fill in between the studs again (with plywood or insulation), as that will ruin any ventilation/air exchange you are currently getting. Air exchange is what is needed to prevent mold and rot.
I don't know what to say - besides that flashing is the least of your problems.
Decoramould is offline   Reply With Quote
Old 12-21-2009, 06:33 AM   #18
flashing and stucco
There are actually exterior trim products on the market that aren't PVC (which tends to expand/contract and peel due to temperature fluctuations) - and work immaculately with stucco.
And you want to avoid using wood as trim on the exterior of your home - it will eventually rot.
Old 12-21-2009, 09:54 PM   #19
flashing and stucco
It may have been poorly installed, but it lasted over 80 years. I am the new owner so I am not concerned about future owner as much as I am concerned about future issues.
BTW my inspector missed it 2 months ago.\
What exterior trim products are there?
I recently has a stucco pro in, an idea that was offered was to bring flashing up the existing stucco and lay a new coat over the new flashing.
Any thoughts on this?
sharp is offline   Reply With Quote
Old 12-21-2009, 09:59 PM   #20
flashing and stucco
also, when stripping down the walls the soffits were filled with blown in insulation, is this right? i understand about the ventilation, but I will have to insulate as it gets cold here. Will just insulate the walls, and remove the insulation in the soffits. Would this work better?
Old 12-25-2009, 08:28 AM   #21
flashing and stucco
IIRC you want the soffits to remain clear to vent the roof/attic. What you want to do is put insulation between the beams that compose the ceiling of your top floor, not the rafters of the roof.
BASF has a blown-in insulation that can go between the roof rafters and will act as a moisture barrier, in which case you don't need to vent the attic. You will need to check local building codes though as some municipalities still don't allow it.
Here: http://www2.basf.us/urethanechemical...tite/index.htm
Edit: Better link: http://www.basf-pfe.com/index.php?lo...ction=ceilings
Old 12-31-2009, 12:26 PM   #22
Dave The Roofer
Dave The Roofer's Avatar
Send a message via AIM to Dave The Roofer
flashing and stucco
The flashing under my stucco is rusted and has many holes. There is water leaking through a majority of them on all four sides of the house.
I would like to know how this may be addressed.
The current flashing is stepped and under both the stucco and the first layer of shingles. If it were to be re flashed would the stucco have to be removed and then reapplied after the flashing? This makes sense but the is nothing behind the stucco except insulation and 2X4s.
How should this be repaired?
Info would be appreciated before a contractor/rofer takes me or a ride and doesn't do the right thing.
Does the Stucco Hold water?
We do not use much stucco in Maine
Dave The Roofer is offline   Reply With Quote
Old 01-01-2010, 09:05 AM   #23
flashing and stucco
In heavy rain water does penetrate the stucco. The inside gets very damp.
Flashing question where eavestrough meets stucco wall? chadurban Roofing 3 12-31-2010 06:42 PM
How to install flashing mrconfident Roofing 3 06-15-2009 04:46 PM
Flashing an existing ledgerboard opssusan Building & Construction 5 02-22-2008 06:48 PM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 01:48 PM
