Flashing And Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-26-2013, 08:28 PM   #1
flashing and shingles
hi all,
I just recently had my flashing around the chimney replaced as it was getting old and rusty. Today I went up on the roof and noticed that some of the shingles around the chimney flashing does not seem to be intact to the metal flashing. I can actually kind of lift it up on the end that's overlapping on top of the flashing.
Is this something that I should be concerned? should I maybe go buy a roof tar and try seal it up?
Tim
re3456 is offline   Reply With Quote
Old 01-26-2013, 08:36 PM   #2
Rewards Points: 13,740
Got a picture? Could be it just has not been warm enough to the adhesive on the shingle to adhere.
Old 01-30-2013, 09:26 PM   #3
Quality Exteriors of CT
QualityRoofing's Avatar
I agree with Joe, the shingles are probably stiff and as soon as the temperature goes up it will flatten down. With out a picture we can only go by what you are saying so a picture would definitely help.
QualityRoofing is offline   Reply With Quote
Old 01-30-2013, 09:34 PM   #4
Roofmaster
Rewards Points: 2,210
Do you mean the tabs of the shingles???? You are supposed to be able to lift them. Dont rupture the glass mat, nat. I mean Tim.
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 04-30-2012 11:42 PM
proper flashing where shingles meet brick tom goodman Roofing/Siding 3 04-26-2012 12:04 PM
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 10:31 PM
