Flashing Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-21-2013, 09:38 PM   #1
flashing question
hello,
I have a question on flashing a dormer. If you have housewrap on the dormer and roofing felt on the roof sheathing I was told to bring the felt up about 6" up the dormer wall then the house wrap overlaps that. That part I understand but if I wanted to add a layer of ice and water shield for a counter flashing that would have to be put on first so its directly attached to the sheathing, correct?
markharmon is offline   Reply With Quote
Old 06-21-2013, 09:54 PM   #2
Roofmaster
Rewards Points: 2,172
Felt into angle change, 18 inch ice dams 9 inches out over felt, and 9 up wall. on sheathiing. House wrap over ice dams. Ice dams is not really used for exposed counterflashing as UV eats it up. It is secondary protection under base flashing, if I understand you.
Old 06-21-2013, 11:43 PM   #3
Ok, so the ice and water 9" up wall and 9" overlapping the felt?
Old 06-22-2013, 06:49 AM   #4
Roofmaster
You know Mark, the way you back into things is really annoying.
Why don't you tell us what you are trying to flash, and we will help you.
Like: "I have a chimney of (Type) which is A x B in dimension, which penetrates my roof which has (Type) shingles, and is sloped at ?/12. The chimney is located Blah Blah Blah.
Giving us information like you are feeding goldfish one little flake at a time is quite maddening.
Old 06-22-2013, 08:29 AM   #5
Rewards Points: 13,472
Still going to need step flashing if there's shingles going on the roof.
Keep the J molding about 1" up off the shingles.
Old 06-22-2013, 08:52 AM   #6
I don't have anything to flash it was just a question. I just though ice and water needed to be directly attached to the roof sheathing.
Old 06-22-2013, 08:37 PM   #7
Roofmaster
No it does not. again, it depends on the situation.
Old 06-23-2013, 07:40 AM   #8
How do you figure it depends on the situation?
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Vinyl siding - flashing question? hosscat Building & Construction 0 01-02-2013 09:46 AM
Roof flashing question homeroofing2 Roofing/Siding 4 12-27-2012 10:09 AM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
