Flashing Over/under Siding Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-29-2013, 04:52 PM   #1
Flashing over/under siding question
I am building a hatch style egress door (of wood can't afford metal or fiberglass now) from basement due to rot from water/ice because of lack of flashing on prior basement door framing. I live in upstate NY lots of snow/ice and the framing will be attached to the side of the house in a corner. How should I flash using rubber roofing (I have lots from a previous job). Also, the reason things rotted at the ground level were because of a previous addition of a patio 50-60 yrs ago that was touching the wood behind the siding (the 2 X 6 planks running vertically). My home is 125+ yrs old. Help! I do realize there should be about 6 inches of sill but its impossible unless I remove 10" thick patio, which is impossible. Any advice is appreciated! Thanks, Tammie
midastocar is offline   Reply With Quote
Old 06-29-2013, 04:54 PM   #2
Having trouble with photo please copy and paste
[URL="https://www.dropbox.com/sc/v2e964o0nd2t7r1/HEseaJsk1u"]
Old 06-29-2013, 07:53 PM   #3
Rewards Points: 13,300
Picture did not work.
Old 06-29-2013, 10:22 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,926
Stone veneer meets siding...flashing? heinlein0311 Building & Construction 67 10-26-2012 08:55 AM
Question about siding and sheathing for garage cyberfire Building & Construction 10 08-02-2012 11:47 PM
Step Flashing Question cdm Roofing/Siding 8 07-31-2012 09:02 AM
Window flashing over T1-11 siding ajhutt Building & Construction 2 05-01-2012 12:58 AM
Siding replacement question MeatballCB General DIY Discussions 16 02-05-2010 03:53 PM
