Flashing Missing. Want To Add - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-23-2011, 02:06 PM   #1
Rewards Points: 93
flashing missing. want to add
I recently found out that part of my roof aren't flashed correctly and I would like to address this issue now.
The main culprit is where the roof butts up to an exterior wall.
I know I have to add step flashing but what is the best way to do this now.
The roof is newer and the wall has wood clapboard with vinyl siding over it. Do I need to get the flashing undr the wood clapboard? Does it need to be attached?
Any advice or tips would be great.
bfan781 is offline   Reply With Quote
Old 06-24-2011, 08:34 AM   #2
Rewards Points: 146
Well, that's certainly a bugger, so first of all, have you actually been up there to confirm that there is no step flashing? (Not doubting you at all, as I have run into the same thing, but just seems like a logical starting point.) You will most likely want them just behing the vinyl, otherwise you'll be dumping water behind it at the bottom of the run. Is it practical to remove the vinyl siding on the affected wall? If the entire roof, meaning up to the peak, adjoins the wall, it might be easierst to start at the top, and remove and relay the shingles along that wall. The shingles are probably laid right tight against the siding, or under it too, right? In which case you'll probably have to trim all of them.
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 07:36 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
