Flashing Job Done- Pics - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-09-2008, 08:28 PM   #1
flashing job done- pics
We had a problem with a leak around the chimney and after posting here it was determined it was a problem with the old flashing. See here for original post. roof leak question
So we had some people come out and give us their opinion and a quote. They said the same thing that ed the roofer said and their price sounded ok so they did the job yesterday. It ended up raining last night and I couldnt find any signs of water so thats a good sign. Anyways they removed a few feet of old shingles, had to replace some rotted sheeting, put down ice/snow guard, flashing and counter flashing and new shingles. Here are the final pics of the job. Everything look ok?
joshm is offline   Reply With Quote
Old 04-09-2008, 08:38 PM   #2
Well it looks a hell of a sight better,IMO they should have cut the shingle behind the chimney a little higher for better drainage.But it should be fine
johnk is offline   Reply With Quote
Old 04-09-2008, 08:43 PM   #3
I usually leave 1/4" space from the wall for drainage and about an 1"or1 1/2 behind the chimney.
Old 04-09-2008, 09:22 PM   #4
For the most part, it looks good and it is the results tha matter now for you.
I would have liked to see the shingles at the top upper portion of the chimney trimmed back for water to flow a little better.
I still would like to hear that they applied the Grace Ice and Water Shield product from the roof deck onto the vertical rise on all 4 sides of the chimney.
I also would like to know if they installed the sealant behind the sheet metal flashings, prior to securing the fasteners, since the encapsulated sealant does more long lasting water-proofing than the exterior top surface bead.
Those comments are only offered to be looking at this project with a magnifying glass. Do not get alarmed by them at this point. If it is working and remains water-tight, it has done everything you wanted to achieve from it, therefor, Good Job.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-09-2008, 09:36 PM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
The top should have been more 'open' to allow water drainage, IMHO also. Thought you can't tell in the pics, there is an inch of space on both sides at the top corners.
If it's working, OK.
tinner666 is offline   Reply With Quote
Old 04-09-2008, 09:55 PM   #6
That's some good drainage!
Old 04-13-2008, 08:58 PM   #7
we cut all ours tight , personally dont like to see any flashing. we do wrap all chimneys , skylights, ect in ice and water and up the vertical surface. have not had a call back in 15 years. ( knock on wood )
jason h is offline   Reply With Quote
Old 04-13-2008, 09:32 PM   #8
Pro Slate Roofer
tinner666's Avatar
Never wrapped one and never needed to. 30+ years and no leaks.
Old 04-16-2008, 01:52 AM   #9
the roofing god's Avatar
Send a message via MSN to the roofing god
says the man from virginia,that won`t work so good in new york with the Ice and snow
looks better,few things I would do differently,but it`s functional.and you got what you paid for
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Do architectural shingles really work with step flashing? Malcolm Roofing/Siding 7 05-02-2008 11:31 PM
Flashing for New Construction Replacement Windows in Stucco House BigJimmy Building & Construction 10 11-03-2007 01:48 PM
Plumbing vent flashing FatAugie Roofing/Siding 7 08-24-2007 09:30 PM
What kind of flashing Malcolm Roofing/Siding 4 06-20-2007 02:59 PM
Flashing problems Slave Building & Construction 3 11-16-2005 04:56 PM
