-   -   flashing help needed (http://www.diychatroom.com/f9/flashing-help-needed-60686/)
endgrainguy 12-31-2009 03:18 PM
1 Attachment(s)
I"m having troubles with the roofing contractor who just did a reroof on my woodworking shop, and he's botched the flashing job required by an attached greenhouse to the building. The greenhouse has a small hinged roof section at its apex that sits on top of the main structure's roof at the main structures eave like a 22 foot long skylight. That roof section is canted slightly so it drains out the end of the building. i originally flashed it using a full length (22 feet)aluminum flashing made to sit on top of the existing shingles, lapped under them at its top, about 18" up the 6/12 pitch roof and then climb the curb of the greenhouse roof and overhang the greenhouse roof a few inches. This flashing was covered with an acrylic coating over canvas from these guys http://www.conservationtechnology.co...g_acrylic.html and worked well if I renewed the acrylic every couple years. If I didn't the roof leaked into the greenhouse in ice dam conditions (I live in western Mass). The replacement flashing the roofer did used three 8 foot long sections lapped over eachother, and only climp up the roof about a foot. The shingles are applied over it in the usual fasion. He also used ice shield under the flashing, adhered to the plywood roof deck before usiong the aluminum flashing. His job leaks in regular rain, the way mine did in ice damning conditins if i hadn"t reneweed the acrylic for a couple years.
He wants me to pay him to repair it, but I don't think he knows what he's doing, and I'd rather repair it myself or pay someone to do it correctly, if that's possible at this stage. His plan is to use a wider piece of aluminum sitting on top of the shingles for the last third of the roof, the part that's leaking. Shouldn't this have been flashed with a single piece, full length flashing rather than in three 8 foot lengths? Can any effective metal flashing be done at this point?
Tom Struble 12-31-2009 08:28 PM
finding a 24ft piece of metal flashing would be difficult
Scuba_Dave 12-31-2009 09:40 PM
I would have used roll flashing, comes in 25' & 50' lengths
Possibly only 18-24" wide
I used some to make my own skylight & chimney flashing
Kinda weird setup to build a roof over the other roof like that
I've never worried about water leaking into my greenhouse as plants need water
So long as it isn't rotting wood on the house/framing etc
tinner666 12-31-2009 10:09 PM
An aside; Did the 'roofer' roof over the bottom half of that heat vent in the middle of the roof? :eek: 1/2 of that shiny metal should be showing plain as day. Covering that is a big no-no. If he didn't have a clue there, no telling what he did at the connector.
http://www.albertsroofing.com/Power%...stallation.htm
I need a close-up of the roof/greehouse connection to understand what he did or didn't do there.
