Flashing Help - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-22-2014, 02:25 PM   #1
Rewards Points: 12
Flashing help
Good afternoon,
I am looking for some guidance on flashing around my LP siding chimney. See attached photos. I started my roof replacement 17 days ago.... Wow completely underestimated the work involved. At any rate I am stuck at the chimney, the photos arent great, but should I remove the siding from the bottom. Any tips for bending the flashing around the corners to overlap the step flashing. The pan flashing I have is 5 x 13, no way it will fit up under the siding. Suggestions from the pros? If I can make it by the chimney correctly I will be home free so to speak
dom350 is offline   Reply With Quote
Old 09-22-2014, 02:48 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,280
Cricket is your friend here.
i.e. chimney cricket.
Old 09-22-2014, 03:19 PM   #3
Rewards Points: 144
Agree with Windows.Cricket and step flashing should do it.
mako1 is offline   Reply With Quote
Old 09-22-2014, 04:36 PM   #4
Rewards Points: 14,026
Some of the siding also has to come off to frame the cricket and to step flash it.
Old 09-22-2014, 07:34 PM   #5
Yes.
I should have explained in more details but I was posting via bad service.
The siding still needs to come up in order to do this properly.
Old 09-22-2014, 09:47 PM   #6
Rewards Points: 12
Originally Posted by Windows on Wash View Post
Yes.
How high should the "Ridge" of the cricket be? if I have a 6/12 slope?
A roofer told me I only needed a cricket if the chimney was larger than 33 inches I think? Does this make sense?
Thanks for everyones replies!
Old 09-22-2014, 10:10 PM   #7
Crickets make good sense regardless of width of the chimney.
The ridge on the cricket should be level however high that requires. That usually provides the best aesthetic.
Old 09-22-2014, 10:18 PM   #8
Make's 0 since.
Any chimney built like that should have had a cricket.
Old 09-22-2014, 11:22 PM   #9
Rewards Points: 12
Make's 0 since.
Sounds good, I will build a cricket then, do I still need to use pan flashing or just step flashing up the the cricket? Also do i need anything special on top of the ridge of the cricket where it meets the chimney. the photo posted earlier of a cricket shows flashing that sits on top the ridge or splitting the ridge.
Old 09-22-2014, 11:27 PM   #10
Need step flashing and counter flashing.
Old 09-23-2014, 07:44 AM   #11
Low Slope Roofing
Rewards Points: 114
I've actually heard 24" but yes it needs a cricket. 2:1 ratio is good to use. If it were mine I'd frame it ice and water shield around the chimney then build a metal pan leaving the pan exposed preferably out of copper but I'm sure I'd cheap out and use galvanized. :D
1985gt is offline   Reply With Quote
The Following User Says Thank You to 1985gt For This Useful Post:
Windows on Wash (09-23-2014)
Old 09-23-2014, 04:28 PM   #12
Rewards Points: 652
I'm gonna go against the grain here and say you can get away without the cricket.
That's a small chimney, a pan will do just fine. Checkout Frank's(tinner666)'s website for the details. He also shows how to do the steps at the ridge if you choose to build a cricket.
PatChap is offline   Reply With Quote
The Following 2 Users Say Thank You to PatChap For This Useful Post:
roofermann (09-23-2014), Windows on Wash (09-23-2014)
Old 09-23-2014, 04:46 PM   #13
Rewards Points: 12
Thanks for the info, i went to the website but do not see an article on Crickets
Old 09-23-2014, 04:57 PM   #14
Rewards Points: 652
https://www.google.ca/url?sa=t&sourc...FB1Pv3iZM6hOxw should be on this page near the end.
dom350 (09-23-2014), roofermann (09-23-2014)
Old 09-23-2014, 08:00 PM   #15
I'm gonna go against the grain here and say you can get away without the cricket. That's a small chimney, a pan will do just fine. Checkout Frank's(tinner666)'s website for the details. He also shows how to do the steps at the ridge if you choose to build a cricket.
Like Frank knows anything....
Ha!!!
The Following User Says Thank You to Windows on Wash For This Useful Post:
PatChap (09-23-2014)
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 04-30-2012 11:42 PM
the very best materials for replacement chimney flashing are? DIherself Roofing/Siding 10 04-19-2012 08:22 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
