Flashing Help - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-14-2014, 11:35 PM   #1
Rewards Points: 82
flashing help
Going to be putting on a new asphalt roof in the coming weeks and almost solved all of my questions, but one problem still eludes me.
I have to poles for my service entrance, one is the typical round pole with the weatherhead, and the other is a chunk of angle iron holding the drop wire (I believe thats the term). Flashing the pole is easy, but how would I flash the angle iron? The previous owner opted for slapping as much tar on as they could and called it finished, and I would rather not do this, but unfortunately I haven't found any other answers online. Any ideas out there other than custom made flashing that needs to be welded on site?
grendel5269 is offline   Reply With Quote
Old 05-14-2014, 11:57 PM   #2
Rewards Points: 6,652
Pictures speak wonders.
Old 05-15-2014, 12:12 AM   #3
Rewards Points: 82
Will take a picture after work tomorrow, little dark now. Good call. Hopefully this thread won't get forgotten about by then
The Following User Says Thank You to grendel5269 For This Useful Post:
roofermann (05-15-2014)
Old 05-15-2014, 09:59 PM   #4
Rewards Points: 82
Lets try again, description as above in OP.
1st pic shows the drop wire on the left connected up to the angle iron. The second pic shows the hack job that was done with tar to seal in the angle iron. The weatherhead mast I'm not concerned with since I will get a split boot for it. Any help would be greatly appreciated.
Old 05-15-2014, 10:20 PM   #5
Take the picture farther back from the ground please.
Old 05-15-2014, 10:44 PM   #6
Doing This Way Too Long
Rewards Points: 532
If the weatherhead is properly mounted and secured to the side of the house then that tension pole is not necessary. I'd remove it and mount everything on the weatherhead like it should be.
Roofing 101 - Think Like Water
OldNBroken is offline   Reply With Quote
Old 05-15-2014, 10:48 PM   #7
Rewards Points: 82
I'm not positive anymore what you want to see if that doesn't show it...My question, how do I flash/waterproof a piece of 1x1 angle iron that is going through a sloped roof?
Old 05-15-2014, 11:06 PM   #8
Post a picture from the ground showing the whole roof line. We can zoom in if needed to see the detail.
You do not have to take a macro zoomed photo showing one part. What we really need is the whole roof and the side of the house, to see what is going on.
Old 05-15-2014, 11:14 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 662
Try here-- http://www.bestmaterials.com/retrofit_adaptors.aspx
The Following User Says Thank You to TheEplumber For This Useful Post:
roofermann (05-16-2014)
Old 05-16-2014, 12:33 AM   #10
Rewards Points: 82
Originally Posted by TheEplumber View Post
Beautiful, that is exactly what I'm after. I searched and searched for it but no luck, Thanks
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 04-30-2012 11:42 PM
the very best materials for replacement chimney flashing are? DIherself Roofing/Siding 10 04-19-2012 08:22 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
