Flashing In The Center Of The Valley - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-04-2012, 12:13 PM   #1
Question
Flashing in the center of the valley
Hello everybody,
I just moved in to a newly constructed home on LI NY. My concern is with the valleys not having shingles in the center on both sides.
There are many houses in the area with similar roof as in my home (without visible shingles). However, some homes do have shingles installed.
I have few questions:
Is this normal ( by code) for the new roof not have shingles installed?
Should I caulk the valleys as my home inspector suggested or should I have roofing guys add shingles? How complicated and expensive is it?
Any suggestion, as always, would be greatly appreciated.
I'll do it! is offline   Reply With Quote
Old 05-04-2012, 12:22 PM   #2
Just a DIY guy
Is that a tile roof? Or really thick shingles?
I'm not a roofer, but I think all tile roofs have metal valleys. Open valleys are better on tile roofs because a closed valley (where all the tiles touch) leads to debris clogging the valley, then water migrates laterally and often gets underneath the tar paper.
M3 Pete is offline   Reply With Quote
Old 05-04-2012, 12:28 PM   #3
my house is on the top picture. The roof is a typical asphalt shingle.
http://www.roofing-nj.com/shingle-roof-installation
Old 05-04-2012, 12:39 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Don't worry about it. Valleys can be fully weaved, half weaved, or open with metal. Caulking will ensure that it DOES leak!
Half weaved, the opposing side should have the cut edge about 2" from the center of the valley.
tinner666 is offline   Reply With Quote
Old 05-04-2012, 12:41 PM   #5
is it a typical caulking job, or I better hire someone?
Old 05-04-2012, 12:45 PM   #6
Pro Slate Roofer
tinner666's Avatar
Did you read my post? Caulk in a valley will cause it to leak.
Old 05-04-2012, 12:47 PM   #7
sorry, I misread it. My bad.
Old 05-04-2012, 11:13 PM   #8
Doing This Way Too Long
Rewards Points: 532
The home inspector told you to caulk the valleys???
OMG How do these people dupe homeowners into trusting their "expertise" on things? My granddaughter knows more about roofing than that guy then.
CAULK IS NEVER THE SOLUTION TO A ROOFING PROBLEM!!!!!!
As for your roof, it looks fine from this distance...if it ain't broke, don't fix it.
OldNBroken is offline   Reply With Quote
Old 05-05-2012, 12:18 PM   #9
He did not insisted on caulking, he rather suggested that caulking might be necessary. More like cover your butt type of deal. Since I am not a roofer, I though I'd verify his comment... I assume that the roof was done to code or it would not pass town inspection.
But I agree with you, if not broken - don't mess with it.
Old 05-05-2012, 12:25 PM   #10
Rewards Points: 790
He might have just said that, regarding a bead of silicone or roofing cement on the underside of the shingles that overlap the flashing in the valley.....that would be okay.
to the OP....flashing in the valley is a common practice. I prefer not to do it, but it can/does work and shouldn't leak if done properly.
In fact, a lot of high end homes in the area I live use this method and have copper flashing which really looks nice.
cibula11 is offline   Reply With Quote
Old 05-05-2012, 12:28 PM   #11
that exactly what he said...
Old 05-09-2012, 08:02 PM   #12
First of all if it's a new home the roof had a final inspection in order to be approved, and you should have received a package that includes warranties from the roofing company who installed the shingles and the manufacture of the shingles Roofing company is responsible for craftsmenship and leaks anywhere from 5 to 7 years after that the manufacture is responsible for performance and defect's Don't be concern with aesthetics, valleys can be done different ways. Calk is good if you mean roofing cement in a tube. You should only use roofing cement, shingles are made from asphalt and roofing cement is made from asphalt too
Jc the roofer is offline   Reply With Quote
Valley with a short flashing rjwrightohio Roofing/Siding 7 10-05-2011 06:18 PM
Valley Flashing ws6gta Roofing/Siding 2 05-18-2011 05:43 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Do I need flashing in the valley for woven shingles? tidal9 Roofing/Siding 3 06-06-2008 11:15 AM
Open valley flashing question steve1234 Roofing/Siding 2 10-01-2007 12:19 PM
