Flashing Around Furnace Chimney From Peak To Eave? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-23-2007, 04:16 PM   #1
Flashing around furnace chimney from peak to eave?
Hi,
I'm shingling a roof and the homeowner wants metal flashing from his peak to the eavestroph centered aroung his chimney. He says it is to prevent fires. I have never done this and I was wondering if anyone has some ideas on how it should be done.
I was going to just shingle the roof as usual and then place the tin (32" wide) around the cimney from the ridge cap to the eave.
Any help would be appreciated.
Thanks.
theredheadedstranger is offline   Reply With Quote
Old 10-24-2007, 10:47 PM   #2
the roofing god's Avatar
Send a message via MSN to the roofing god
you should post a pic of the area
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 10-25-2007, 10:34 AM   #3
What is wrong with using Class A fire resistant rated shingles?
Or, just give him a bid for a metal roof instead. One section in the middle would look like chit.
Ed
Ed the Roofer is offline   Reply With Quote
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Painting metal flashing around chimney abelsu Painting 3 05-17-2007 02:09 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Chimney Liner vs New Furnace jeff_connors HVAC 4 01-11-2007 01:41 PM
Advice Needed re: Chimney Liner for Oil Furnace Mike_R HVAC 3 11-27-2006 04:04 PM
