Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 10-08-2010, 09:19 AM   #1
I ask the impossible!
Flashing around chimney at ridge
Could someone walk me through how to flash a chimney that is at the peak of a roof? I get how to do the apron and the step flashing, so it'll have an apron on both sides, so when the step flashing gets to the top of the peak should there be something done differently or how does that work?
WillK is offline   Reply With Quote
Old 10-08-2010, 06:41 PM   #2
Shut in w/o Home
seeyou's Avatar
You can make your own ridge flashing out of two step flashings or buy a pre-made piece.
http://tiny.cc/4w7sw
seeyou is offline   Reply With Quote
Old 10-18-2010, 08:24 AM   #3
RoofDiagnostics's Avatar
Flashing a chimney is no different at the peak then in the field of the roof. to properly flash the chimney you need to:
1. Grind a regret joint.
2. Install step flashings
3. Install ice/water shield underlayement surrounding the base of the chimney
4. Fabricate and install counter flashing - this will be inserted into the reglet joint on the surface of the chimney.
5. Install the shingles surrounding the chimney
Hope it goes well!
RoofDiagnostics is offline   Reply With Quote
Old 10-18-2010, 09:17 AM   #4
Well, what I don't really get is the part where you're going over the peak itself... Maybe I'm overthinking it, but it seems to me like there's always going to be a small area where the flashing can't really block water because you can overlap the step flashing from one side over the other where it goes over the peak, and you can overlap the part that goes onto the chimney but at the corner at the peak, you can't really overlap the 2 pieces... Is that just the way it is and you have to seal that with goop?
Old 10-18-2010, 09:21 AM   #5
the step flashings (the flashings that you do not see, once the job is finished) will have a gap where the two meet. you can make your own step flashing to fit this area. Sometimes we make a custom step flashing to fit the area - other times we leave the gap. The counter flashing is essential to the water tightness. Make sure you do a very good job with the counter flashing.
Old 10-18-2010, 09:25 AM   #6
http://www.ashireporter.org/articles...f-Figure-4.gif (look about halfway down the page)
Old 10-19-2010, 08:29 PM   #7
Pro Slate Roofer
tinner666's Avatar
Near the bottom of this page is a step by step detail of the finish pieces. http://www.albertsroofing.com/Chimney%20Repair.htm They get fully locked together before nailing either. A dab of caulk on each side will do ya.
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Michael Thomas (10-20-2010)
Old 10-20-2010, 09:38 AM   #8
Great pictures, that really gets me the level of detail I needed! And just in time, I'm wrapping up this area today so I can get my roofing brackets down and get the pics of the house I need for my new insurance.
ridge vent and flashing around chimney cupcake8 Roofing/Siding 4 09-27-2010 05:40 PM
Bad job replacing chimney flashing? TNVolFamily Roofing/Siding 12 02-28-2010 08:04 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 11:27 AM
Looking for Chimney Flashing Kit. Prefabricated? gante Roofing/Siding 11 02-27-2009 10:11 AM
