Flashing Around Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-11-2011, 09:37 PM   #1
flashing around chimney
I am putting on a new roof and wondering what the proper step-counter flashing methods are for around a chimney???......thanks
kskier is offline   Reply With Quote
Old 10-11-2011, 10:05 PM   #2
Gymschu's Avatar
Rewards Points: 236
A picture would do wonders for getting answers to your question. Usually step flashing followed by counter flashing...........but, every chimney is different & some require special work to properly flash them.
Old 10-11-2011, 10:28 PM   #3
I know alittle about alot
JWilliams850's Avatar
very carefully
JWilliams850 is offline   Reply With Quote
Old 10-11-2011, 11:05 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I've put many of the details on my website, in my sig. Browse to your heart's content. I think you'll find all your answers there.
tinner666 is offline   Reply With Quote
Old 10-11-2011, 11:19 PM   #5
Registered User
Rewards Points: 4,924
kskier, please post same question only once, thank you.
I see a pro roofer answered before me but I'll give you the link I found anyway:http://www.rumford.com/chimneys/flashing.html
Gary
Old 10-12-2011, 10:27 AM   #6
old timer
kskier,
It depends on the type of chimney and roofing being installed. Here is a site with different chimney flashing examples.
A short chimney flashing video
And some links to the best videos for chimney flashing
dmc@RCR is offline   Reply With Quote
Old 10-12-2011, 04:20 PM   #7
Pro Slate Roofer
tinner666's Avatar
As you can see, there are many styles. The critical areas are the corners. Like the 60 year old galvanized in the link, I much prefer the ole style with tinner's wings on the corners. The style dates back centuries before caulk was commonplace. No reliance on caulk or solder as the metal hides the corner detail from windblown rain and snow. It's ideal for rookies and your work can be less precise.
The devil is in the details. Step flashing needs to be bent less than 90 degrees and pushed into place. The steps must lap each other correctly. The corners must be protected.
The termination flashing on the first piece across the front of the chimney must be cut so it's 1/8" wider than the chimney to ensure a tight fit when that first step flashing rounds the corner. No gaps that way.
Old 10-12-2011, 06:22 PM   #8
Rewards Points: 956
my looks like this:
federer is offline   Reply With Quote
Old 10-12-2011, 07:06 PM   #9
kwikfishron's Avatar
Rewards Points: 90
Originally Posted by federer View Post
my looks like this:
kwikfishron is online now   Reply With Quote
Old 10-12-2011, 07:12 PM   #10
Rewards Points: 956
Originally Posted by kwikfishron View Post
uh oh. tell me whats wrong
Old 10-12-2011, 07:37 PM   #11
Rewards Points: 90
I’m no roofer, although I’ve done plenty of roofs and flashed plenty of chimneys and none of them looked like that.
I will say I’ve never had the pleasure of terminating rolled roofing into a chimney before so I’ll reserve my comments and let the big guns weigh in.
Old 10-12-2011, 07:55 PM   #12
Rewards Points: 252
Where it is a chimney on the perimeter of the roof there`s nothing wrong with that method.
shazapple is offline   Reply With Quote
Old 10-12-2011, 10:33 PM   #13
Rewards Points: 956
Iím no roofer, although Iíve done plenty of roofs and flashed plenty of chimneys and none of them looked like that.
I will say Iíve never had the pleasure of terminating rolled roofing into a chimney before so Iíll reserve my comments and let the big guns weigh in.
yea i mean it does look weird. they did a first layer of flashing underneath with the roofing tar cement. then they capped it off with the bar
Old 10-16-2011, 07:46 PM   #14
Rewards Points: 156
skirt
im looking at using flashing and forming a skirt at the outer area >its a 1 piece form for going across outer lowest point of chimney.Is this a good option with metal roofing?
I was looking at cutting grooves in flashing for water flow onto the wavy curves of roofing.Joining onto original flashing on sides with skirt 3 inches on sides.
hidden 1 is offline   Reply With Quote
Old 10-16-2011, 08:12 PM   #15
Rewards Points: 156
here is what i was speaking of
Stucco and Flashing at Base of Chimney Need Repair vcheez Roofing/Siding 15 11-10-2011 06:39 PM
Need help deciding giving this chimney flashing contractor a second chance tracyj Roofing/Siding 3 03-29-2011 10:56 AM
Bad job replacing chimney flashing? TNVolFamily Roofing/Siding 12 02-28-2010 08:04 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
Which flashing tape for Chimney flashing? gante Building & Construction 9 03-19-2009 11:27 AM
