Flashing Against A Wall - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-25-2010, 10:15 AM   #1
flashing against a wall
Hi all,
I just bought an old greek revival fixer-upper, and one of my first projects it to fix a roof leak. The spot is where a wall (horizontal wood siding) and a porch roof (asphalt shingles) meet. The previous owner just slapped a piece of flashing right on top of everything, which of course doesn't work at all.
Can anyone suggest a thread, tutorial, or book that will show me the best way?
DanConnor is offline   Reply With Quote
Old 10-25-2010, 02:57 PM   #2
RoofDiagnostics's Avatar
the short answer is:
You need to fabricate and install a flashing detail that is either under - or- into the wall surface & in shingle fashion onto the roof surface.
If the siding is vinyl or aluminum you can remove the bottom few courses and get under the siding... If it is Brick or masonry, you will need to grind a reglet joint.
If the wall is rising wall, like the side of a dormer, you will need to install step flashings. If it is a horizontal run, you should install a counter flashing.
I didn't have much time to find a detailed drawing or sketch but >>>
Towards the bottom of the page should give you a good idea.
Hope this helps!
RoofDiagnostics is offline   Reply With Quote
kitchen clean slate bubbler Kitchen & Bath Remodeling 4 10-19-2010 08:01 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Removing a 4 foot opening in a load bearing wall (for fish tank) ~callie~ Building & Construction 1 07-15-2009 05:10 PM
Breaking up a long/continuous wall tigereye Interior Decorating 4 03-08-2009 03:43 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
