Flashing Against Brick? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-22-2007, 10:27 AM   #1
Rewards Points: 152
Flashing against brick?
I am going to put a roof on an addition that will butt up against the brick exterior wall of my house. Does anyone know the best way to do the flashing?
Thanks!
sandyman720 is offline   Reply With Quote
Old 03-22-2007, 11:16 AM   #2
Commercial Roofing
AaronB's Avatar
Yes, bend it to the roof-to-wall angle, leaving it underbent a degree or so, Cut a chase (reglet) into the masonry joint, install a cleat so as to eliminate exposed fasteners on the roof portion, wedge anchor it to the masonry reglet, and mortar it in.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-22-2007, 11:19 AM   #3
Rewards Points: 152
Do they sell flashing in different colors other than the normal aluminum? I think that an alum. flashing will look kind of weird against my brick home and tan shingles.
Old 03-22-2007, 03:30 PM   #4
Commercial Roofing
AaronB's Avatar
you can get sheet aluminum in a multitude of colors.
Old 03-22-2007, 05:36 PM   #5
Rewards Points: 150
I would agree with Aaron but would like to specify that the apron flashing and counterflashing should be two separate pieces to allow for expansion. the counterflashing is inserted into the reglet that has to be groung out with a gringer, held in by lead wedges and sealed with a urethane calking "like tremco dymonic" a color matches the morter joint. you can also use copper or lead.
RooferJim
www.jbennetteroofing.com
RooferJim is offline   Reply With Quote
Old 03-22-2007, 06:41 PM   #6
Rewards Points: 152
where would be a good place to get the sheet alum. in different colors?
I dont think home depot and lowes sells it right?
Old 03-22-2007, 08:36 PM   #7
Commercial Roofing
AaronB's Avatar
Well, HD has narroe rolls min brown.
Jim, the cleat i use on the roof side allows for expansion...I made this spec up, it works, but is criticized by many. Whats a roofer to do?
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Counter flashing where roof meets vertical brick wall sandyman720 Roofing/Siding 5 02-20-2011 10:13 AM
Flashing for Brick Wall sandyman720 Roofing/Siding 5 08-08-2007 10:05 AM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
Flashing problems Slave Building & Construction 3 11-16-2005 03:56 PM
