Flashing advice
1 Attachment(s)
What is the correct way to flash the corner where the roof meets the siding corner (see photo)? (The far side of the roof where it extends past the siding a foot or so.)
yea you see that alot on older houses with wood siding,nowadays you would hold the siding up from the roof an inch or so,i like to see the first piece of step flashing running past the corner and the first siding course cut around it
The flashing should have been installed before the siding was installed. No way to flash it now without removing the planks.
I'm in luck - I'm doing my roof this weekend (if the weather holds up) and that's why I'm asking. So I'm going to pull all of the siding and be able to start fresh.
I'd like to be able to solder some flashing that would match all the angles - the "front" vertical face under the siding, the "side" vertical face of siding, the pitch of the roof, and the side of the roof that extends out past the siding. Otherwise I'll have to use multiple pieces of flashing that overlap each other. |
step or stair flashing? Anyway, always nice to see an eager DIYer..you go girlfriend!!:laughing:
the sides do need individual step flashing,don't try to do these in 1 piece
A piece of roofing, a piece of flashing, a piece of roofing, a piece of flashing all the way up the wall. After you’re done roofing lay a 1x on the roof and cut your siding to that. Slip out the 1x and you’ll see the flashing stepping up the wall. The gap will help keep the siding from rotting and give you (or the new owner) plenty of room for another layer of roofing some day. PS. Don’t forget the new paper on the wall that laps over your new “Step Flashing” for the Siding. |
1 Attachment(s)
I'm well aware of how to use step flashing and the whole process of flashing/siding the side of a house.
Everyone take a look back at the photo and pretend you're sticking your head out the window. The 18" wide section of roof extends out past the side of the house 12" or so. So, there is a board that is vertical behind what you can see from this photo, that could be seen from the window. I need to know how to flash this corner where 4 different planes are coming together, similar to what "seeyou" posted like the front of a chimney or front of a dormer, except half the front apron would continue down the side of the house. |
1 Attachment(s)
1. Is there a pre-made piece that would work here? 2. Or what combination of flashing would I use?
See this photo for another location but with the same scenario: |
The piece that I pictured addresses three planes: Two wall and one roof plane. I can't visualize where one piece of flashing will touch four planes. Please explain. I don't see it in your photo.
And that piece is for sale online. I can't post a link here, but it's called a "front corner flashing". |
Do you see how your dormer sits completely up on the roof, while my roof breaks in front of my dormer? The apron of your flashing would sit out in space, so I'd like one that would continue down the front of the siding and the vertical wall (white) of the projecting roof. I'll google that "front corner flashing". Thanks for the help so far.
1 Attachment(s)
You don't need any special pieces for that. With the siding and roofing removed, slit a piece of standard step flashing down the fold a couple of inches. Line the bottom of the slit up with the top of the roof sheathing and bend one side down on the roof. the other side will remain on the wall. Slit another piece in a similar fashion and lay it on the roof against the side of the dormer with the slit on the bottom end. Fold one of the tabs around the front of the dormer. Solder them together. Start installing shingles and step flash conventionally right over the special flashing you made. Belt and suspenders. |
IMO, you want to extend the flashing down from the dormer corner and over the drip edge at the eave, terminating in a kick-out to divert water into the gutter - otherwise you will have a little waterfall running down the wall below the dormer corner:
http://paragoninspects.com/images/te...mer-corner.jpg I would step flash to the dormer corner, overlapping a continuous piece of flashing down to and overlapping the drip edge - the result might not be ideally atheistically, but if you want optimum water control.... |
| All times are GMT -4. The time now is 06:31 AM. |
