Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-26-2010, 08:36 AM   #1
Rewards Points: 109
flashing
How do you go about flashing a transite flue. This is what I have with a chimney liner that runs through it.
hitmehhh is offline   Reply With Quote
Old 08-26-2010, 09:32 AM   #2
fabrk8r
fabrk8r's Avatar
If you can provide more details it would really help.
Are you needing to add flashing on your roof?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-26-2010, 10:15 AM   #3
Rewards Points: 109
flashing
It is about a 3/12 roof with bitumen on it right now. It comes through the roof and only has mastick around it as do many of the houses in this area with these transite flues.I want to know what is the proper way to flash this type of flue?
Old 08-26-2010, 07:30 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Is it oval shaped? We've had to make custom flashings the few times we've encountered transite flues. The ones in my area are shaped to fit through stud spaces.
seeyou is offline   Reply With Quote
Old 08-27-2010, 07:48 AM   #5
Rewards Points: 109
No , its round.
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 01:50 PM
flashing help needed endgrainguy Roofing/Siding 3 12-31-2009 11:09 PM
Need roofing tips! dc4nomore Roofing/Siding 114 07-03-2009 08:01 AM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 11:00 PM
