Which Flashing? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-18-2013, 01:33 PM   #31
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Now I'm going to have to go up there and check that corner. I remember looking at it when it was done and don't recall that part being soft (nothing behind it). Considering all the saw dust that was around, I would be surprised if he didn't put a small strip in there.
Old 04-18-2013, 05:13 PM   #32
Metal Roofing
Rewards Points: 600
You have about 20' of roof to wall to deal with based on the pics. The two pc would be ideal and if polling thats where my vote goes. I have no idea what they charge for the metals, but you dont need much, it would be a wise choice.
Your alternative is one like in the spec you posted but slightly improved. The hem is a nice feature so i would add that. Also, you could extend the lower section from 3.5" to say 5"+. This would give you a little more play in the flashing for when the time comes to re roof. You could price it both ways and see what your saving vs going with something from Fry Reglet.
AndyWRS is offline   Reply With Quote
The Following User Says Thank You to AndyWRS For This Useful Post:
1985gt (04-19-2013)
Old 04-18-2013, 09:18 PM   #33
Roofmaster
Rewards Points: 2,210
All drip metal that I specify has a drip with a return hem. (Thats what we call it when the metal is turned back on itself at 180 degrees. The kick adds a lot of columnar strength to the metal and prevents bowing. The return hem is to keep people from slicing their hands and feet open from a sharp edge, and if Kynar coated steel is used, it prevents rust from starting at an unhemmed drip. Galvanized, steel moves at about half the rate of aluminum.
Monumental buildings always used to use lead coated copper for its malleability. It was relatively easy to bend it up, re-flash and bend it back down. Not so with Stainless, ALuminum, or Steel.
I already posted my 2 cents about how to properly install base flashing.
You've got 4 pretty experienced people telling you that you should have a cant strip, and you should listen to them, but I guess the cow is out of the barn on that one. I would personally never allow a bituminous low slope roof system to be installed without cants. The value of the 4 inch high water dam cannot be over stated, and Bridging and cracking will occur at a 90 degree turn in any bituminous product in time.
The Following User Says Thank You to jagans For This Useful Post:
1985gt (04-19-2013)
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Re-roofing: flashing question prb_nearnorth Roofing/Siding 9 04-30-2012 11:42 PM
the very best materials for replacement chimney flashing are? DIherself Roofing/Siding 10 04-19-2012 08:22 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
