Flashing - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-23-2011, 07:10 AM   #1
Rewards Points: 154
flashing
when flashing is it necessary to use step flashing? or can i use a piece of flashing 10 feet long?
awdblazer is offline   Reply With Quote
Old 06-23-2011, 07:36 AM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
We have to assume you are flashing a roof to a side wall.
Use step flashing ...always.
Go to You tube and type in "step flashing."
tcleve4911 is offline   Reply With Quote
Old 06-23-2011, 07:57 AM   #3
Rewards Points: 154
yah roof to side wall
thanks for the quick reply
you use one piece of flashing per row of shingles?
Old 06-24-2011, 07:54 AM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Correct
seeyou is offline   Reply With Quote
Old 06-26-2011, 07:03 PM   #5
Registered User
Rewards Points: 526
You may also need kick-out flashing at the bottom, this from one of our members: http://paragoninspects.com/kickout-f...hicago-il.html
Gary
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing/Siding 9 09-25-2014 11:53 AM
Roof to Wall Flashing Installation Painted Cedar Lap Board Siding Deeppool Roofing/Siding 3 12-08-2010 07:36 AM
Flashing repair Squash_Pro Roofing/Siding 9 05-07-2010 12:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
