Fix'n Nail Pops - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-10-2013, 09:46 AM   #1
Rewards Points: 240
fix'n nail pops
i had a nail pop. i got up there and pulled the nail. shingle still stayed up about 1/2"ish. i put some automotive grade silicone in there and a few bricks on top.
temps about 45deg, low 30's over night.
bad idea or ok ?
Fix'n it is offline   Reply With Quote
Old 11-10-2013, 02:27 PM   #2
Rewards Points: 154
The way to do it is to drive a fresh nail in near the old one, seal the old hole with roofing cement, seal the edge of the shingle with roofing cement, then use the brick to hold the shingle down for long enough for the seal to dry. So if you are hoping automotive regrade silicone and a few bricks are a permanent fix, then no it's not ok.
eharri3 is offline   Reply With Quote
Old 11-10-2013, 08:11 PM   #3
Rewards Points: 240
well, i took the bricks off. it is holding strong. time will tell.
how would a nail be driven in, under another shingle ?
Nail pops oz1907 Roofing/Siding 5 09-02-2013 12:41 PM
Nail pops on very old sheetrock george5558 Drywall & Plaster 4 09-17-2012 08:26 PM
Drywall nail pops repair? ProudMarineDad Drywall & Plaster 1 06-23-2009 08:17 AM
nail pops nat Carpentry 3 11-11-2006 12:48 PM
