Fixing Soffit - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-19-2011, 03:06 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
Fixing soffit
Last year I made a hole in the soffit with intention of venting a fan out but I was unable to do it that way as I could not physically get even close to that spot in the attic so I could run the pipe. So I just put vapor barrier tape as a temp fix so bugs and perhaps even small rodents don't get in. I want to fix this properly, what is the best way to patch a hole like this? I suppose soffit designs change all the time, so the odds of finding a piece that looks exactly like mine is probably slim. Is there a standard way to fix something like this?
Old 06-19-2011, 03:40 PM   #2
kwikfishron's Avatar
Rewards Points: 92
What kind of soffit? How about a picture RS.
kwikfishron is online now   Reply With Quote
Old 06-19-2011, 04:58 PM   #3
Wire Chewer
Rewards Points: 46
Added a pic. Not the same part but it's the same all around.
Also forgot to mention, I have gutters, so I can't remove the fascia cover, which would be required to remove/insert a new soffit piece. I could maybe try to pry it but would probably do damage.
Old 06-19-2011, 07:38 PM   #4
Tom Struble's Avatar
Rewards Points: 2,002
you can remove a piece and replace it usually with little or no damage
or you can just put a round vent cover to fill the hole,only you will know
Tom Struble is offline   Reply With Quote
Old 06-19-2011, 08:47 PM   #5
Wire Chewer
Rewards Points: 46
Was thinking of putting a vent cover too, I might just do that. I guess I could try to remove a piece and see how easy it is. From there if I bring it to a hardware store they might be able to match it I guess. Worth a shot. Would also give me a chance to see if the wood behind it is cut or not. Can't see from the hole.
Vinyl Perf Soffit over Wood - No Vents nickelshine Roofing/Siding 18 05-29-2012 10:12 AM
Basement Fireblocking within HVAC Soffit ssmith147 Building & Construction 3 12-31-2009 07:36 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 08:47 PM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 05-01-2007 12:14 AM
