Fixing Eaves - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-29-2011, 06:34 PM   #16
Rewards Points: 91
ok so is the part deteriorated part of the decking board? or just some trim?
no_Wedge is offline   Reply With Quote
Old 04-01-2011, 09:10 PM   #17
Rewards Points: 91
here is two photos showing better the layout, and a corner that has deteriorated.
Old 04-02-2011, 06:35 AM   #18
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
I think what we're looking at is cedar shingles overhanging the shingle mould to create a drip space. I suspect the shingle mould was added beyond the edge of the sheathing, so a course of cedar shingles was added to extend the sheathing. Are the gaps random or all the same width?
The "eave" is the bottom of the roof - where the gutter would go.
The "rake" is the sloped sides of a gable roof.
This appears to be a hipped roof, which would not have rakes.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
MJW (04-02-2011)
Old 04-02-2011, 11:09 AM   #19
Rewards Points: 91
The gaps are all the same width around the entire house, I looked at hipped roof and this is exactly what it is, weird cause it's the only house on the block with this type. I took a couple pictures up close to attempt to see inside the space.
Caulk under eaves or not tns1 Roofing/Siding 1 11-05-2010 03:41 PM
Can you add eaves birdmand Roofing/Siding 2 01-10-2010 09:59 AM
Will boxing-in roof eaves exacerbate mold growth? pnlop1 Roofing/Siding 3 12-25-2009 07:08 AM
negative eaves on ends kaarina123 Roofing/Siding 1 11-16-2008 08:58 PM
Building overhang eaves and soffits on old house justdon Remodeling 6 07-04-2008 09:59 AM
