-   -   Fix or Replace Roof Tile? (http://www.diychatroom.com/f9/fix-replace-roof-tile-141908/)
greentrees 04-28-2012 06:17 PM
3 Attachment(s)
I have a cracked Roof Tile (Monier). Its a flat tile. I live in Sacramento, California so the weather going forward is pretty mild, so no concern for at least two weeks.
I don't know where to get a new tile, so I was thinking if I can just wrap it up in Saranwrap temporarily or some other quick fix, until I can figure out how to buy a new tile. As you can see from the photo, the two pieces match perfectly, so I was thinking there is some kind of glue I can use if I cannot find the right tile at a store.
I will check Lowe's and Home Depot, but didn't see anything on their website.
Any ideas on a temporary fix or a place to find a new roof tile?
Roofmaster417 04-28-2012 07:26 PM
http://www.geocelusa.com/products.ht...page.tpl&pop=0 :thumbsup:
Roofmaster417 04-28-2012 07:34 PM
That will do for a quick fix.,,Check your local roofing suppliers for the adhesive and the tile replacement if needed.Make sure you clean both pieces where the adhesive is placed.Gently with a wire brush to remove dirt,dust and debris.
Most times the new tile will look out of place and obvious if in the front or main focal point from the entry to your home because the color will be richer than the rest of the tiles.
If your feeling froggy it might be best to remove one from a less visible area and place it where the cracked one was and put the new one in the less visible area.
concretemasonry 04-28-2012 08:35 PM
Monier is a huge ($1,500,000,000 sales) international company. Some of the U.S. companies (concrete mainly) were sold off and may operate under different names now, but the shapes made using the same equipment, processes and materials may be available under different names. Two suggestions are to contact local suppliers than may have sold the product or look for other homes in the area and try to find someone that may sell you a spare from and unexposed area - the other choice is glue.
As Roofmaster417 suggested, relocation of a unit from an inconspicuous area may be an option since it would be a better match with similar weathering exposure.
Dick
AndyWRS 04-28-2012 09:33 PM
ABC supply
I am sure if you locate a roofing supply company in your area they will have it. Take the broken one with you!
Do not go to HD or Lowes.
tinner666 04-28-2012 09:48 PM
Replace. No fix will last for any lenght of time.
greentrees 04-29-2012 12:07 AM
I'll check online and the yellow pages to find a local roof supplier. Since it is getting close to summer, the adhesive would do if I can't find a local place that has the tile.
If the tile stands out, I can place it in another location as you mentioned.
seeyou 04-29-2012 05:44 AM
Try these guys:
http://www.tileroofs.com/
http://www.customtileroofing.com/lookingfortile.asp
http://www.claytileroof.com/salvage.asp
greentrees 04-29-2012 02:13 PM
I read that a two part epoxy (resin and hardener) would be able to bond concrete tile. And a fiberglass sheet can be added to the back with the epoxy holding it on, would add strength.
Has anyone tried this?
bob22 04-29-2012 05:42 PM
Why not just get a new one instead of re-engineering a broken one?
tinner666 04-29-2012 06:06 PM
To date, no company or person has made anything that will fix the tile, or anay other roof product. For now, just use a piece of .019 or thicker aluminum the same size of larger then the tile as a bib under the broken tile to catch and keep any rain going down the roof and over the tile below it.
greentrees 04-29-2012 07:41 PM
I was checking for a temporary solution until I can find a new one.
If I put the aluminum under the tile, I would still have to use epoxy to keep the broken piece from sliding down, or just not put the broken piece on, and just have the aluminum act as the bottom part of the tile.
One problem might be that aluminum has no grip, so the tile may slid down since only the weight of the tile on top of it and the notch holds the tile in place. And the aluminum is between the the tiles, creating less surface tension. The aluminum would have to be flexible to mold to the back of the tile. Or just make an aluminum tile as a temporary replacement of the whole broken tile.
AndyWRS 04-29-2012 08:20 PM
Green your over thinking this.
That is a common tile, go to ABC Supply with the broken one, they will sell you a new one or get you one from the bone yard. It will take no more time than running to HD or Lowes to get caulking. in fact, the patch will take you twice as much time, once to patch and once to go to ABC and buy the tile.
Why not just skip the bandaid, you will end up saving time and $ in the long run.
greentrees 04-29-2012 11:16 PM
Being the weekend, I'll give them a call tomorrow. Just thinking of an alternative if is takes a few weeks to get the new tile.
tinner666 04-30-2012 05:23 AM
I apologize for not being clearer.
The piece of metal needs to lay under the two adjacent tiles, minimum 2", and at least 2-4" under the upper tile. It should lap over the lower tile by 2"-5". Just stick the broken one in place for looks on top of it. The metal is the waterproofing piece. Get a new tile and replace the metal and broken tile when you can.
Feel free to bend and flex the metal as needed to get the desired result. Turn the top edge up a tick or two to defeat windblown rain. Turn the bottom edge down a tick or two to hug the lower tile.
