Finishing The Underside Of A Shed Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-02-2012, 09:33 PM   #1
Finishing the underside of a shed roof
I am building a small 12x20 "cabin" for my father to live in. We will be putting a shed roof on it. Can I simply finish the underside of the rafters (2x8) with sheet rock to create the finished ceiling? If so, are there any things to consider or be concerned about?
jmarsh9049 is offline   Reply With Quote
Old 09-02-2012, 10:03 PM   #2
Rewards Points: 13,740
Could you go back and add where you live to your profile, If not people are going to be asking over and over.
Were going to need that to let you know about what insulation your going to need.
Why a shed style roof and not a gable roof?
With a gabled roof it's easer to vent so the building stays cooler in the summer and the shingles last longer.
Have you checked to see if a permit is needed?
Old 09-02-2012, 10:07 PM   #3
I live in Texas ...no permit necessary. We figured the shed roof would be easier to frame for us.
Old 09-02-2012, 10:12 PM   #4
Easyer to frame but it would be like an oven in there.
You could even just order trusses already made. There not that expencive.
What do you plan on for a foundation?
Old 09-02-2012, 10:15 PM   #5
Pier and beam ... floor is framed and decked and walls are framed. Planning on roll insulation plus foam board for insulation.
Old 09-02-2012, 10:34 PM   #6
You did insulate under the floor and add a vaper barrer on the ground, right?
2 x 6 walls? Really need them so you can fit in enough insulation.
installing a metal roof on a shed will02 Roofing/Siding 15 04-08-2014 02:41 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Insulating/Vapor barrier/Venting a 2/12 pitch Shed Roof with Cathedral Ceilings cmlarsen Insulation 6 12-21-2011 09:50 PM
add shed roof to gable roof lucy1 Roofing/Siding 0 10-30-2011 08:31 PM
Shed roof addition & insulation qustion radgumbo Roofing/Siding 2 12-06-2010 05:33 AM
