Finishing An Attic...insulation Question... - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-29-2009, 03:16 PM   #1
Finishing an attic...insulation question...
We just bought a new house, and are working on finishing the attic.
We are trying to insulate the attic ceiling/roof. There is already 'blown in' insulation on the floor.
When installing baffles on roof, do they go from the soffit all the way to the top of the roof (peak)? Or should we stop at the 'proposed' finished ceiling height? And do we also need to insulate the finished ceiling space?
From what we understand, the instalation order would go:
baffle-insulation-vapor barrier across the joists-finishing material?
Thanks for any info!
slyons is offline   Reply With Quote
Old 03-29-2009, 04:50 PM   #2
Residential Roofer
Slyfox's Avatar
Baffles start at the eave and stop just beyond the finished ceiling.
Assuming the new ceiling flattens out at the top it will also need insulated.
Sorry, not familiar with the vapor barrier regulations.
Things like that change quite often from one region to another.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 03-29-2009, 06:53 PM   #3
Correct.
By having the vapor barrier installed, you will prevent any permeation of condensation transfusing through the ceiling material into the rafter bays.
Will the attic room will have a cathedral/vaulted ceiling all the way to the peak, or will it stop short and flatten out, giving a level ceiling appearance at the top after headroom clearance has been achieved?
Ed
Ed the Roofer is offline   Reply With Quote
Old 03-29-2009, 10:13 PM   #4
Agreed!!
Originally Posted by Ed the Roofer View Post
Correct.
Ed
Thinking it will flatten out for ease of lighting fixtures ect.
Space will more or less be "escape space"
OK so you guys say stop baffle at finished ceiling, Guy at Hom* *epot, says soffit to "knee" wall.
I Kinda want to agree with up to "finished ceiling so there is air space between insulation and roof, over the common space above ceiling with poly and insulation. The whirly bird and roof vent working with soffits. Even if guy was right, What will it hurt to do our way other than possible save my roof.
I always thought you want to make sure insulation doesn't "touch" the roof?
Old 03-30-2009, 12:11 PM   #5
Probably 90% of supposed roofers would get it wrong too, so I hardly put any weight into the guy not doing the roofs, working at the desk at Home Depot.
I have always wondered why so many home owners put so much credence into what the store aisle clerk suggests.
Ed
Old 03-30-2009, 12:55 PM   #6
Because we don't know any better
Old 06-18-2011, 09:36 PM   #7
ok, just joined and saw this thread...
what about the cross-bracing. i figure they can be removed if the roof is braced in a different way and also since the roof is finished it shouldn't shift...
correct?
jester10 is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
question about running romex in attic ceiling jayp Electrical 5 03-20-2009 02:06 PM
AH In Extreme Cold Attic Question Home Air Direct HVAC 6 03-14-2009 10:02 PM
Attic Insulation Quote...what do you think? mitchel Roofing/Siding 15 08-06-2008 08:10 AM
Question about attic moisture Mastershredder Roofing/Siding 3 03-19-2007 05:32 PM
