Fill Void From Rotted Drip Edge - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-03-2013, 08:37 PM   #1
Fill void from rotted drip edge
Well I'm continuing some painting from last season and I have an issue I've yet to address that I could use some advice on. The old drip edge was far beyond salvageable and was removed. The PVC drip edges sold at Menard's simply aren't big enough to reach the bottom clapboard. The last picture is an angled shot of an intact drip edge on the other side of the house. First time poster thanks in advance.
Fill void from rotted drip edge-forumrunner_20130703_203256.jpg   Fill void from rotted drip edge-forumrunner_20130703_203312.jpg   Fill void from rotted drip edge-forumrunner_20130703_203320.jpg   Fill void from rotted drip edge-forumrunner_20130703_203333.jpg
phw86 is offline   Reply With Quote
Old 07-03-2013, 08:42 PM   #2
Sorry, I believe they are called "drip caps" not "drip edges"
Old 07-03-2013, 08:50 PM   #3
Rewards Points: 13,300
May be able to add a strip of vinyl lattice on the bottom of the drip cap to make it wider.
phw86 (07-04-2013)
Old 07-03-2013, 09:03 PM   #4
Thought about something similar, but there would be a small gap to deal with. I was also thinking of securing the "to small" PVC drip cap and then putting a pre-folded aluminum drip edge over it. The drip cap wouldn't reach the clapboard but the aluminum would...
Old 07-03-2013, 09:39 PM   #5
Update: attempting another route. I successfully removed the bottom clapboard. My plan is to reattach the clap board slightly lower. I will update with details asap. Still open to other suggestions as well. Thanks.
Old 07-04-2013, 11:10 PM   #6
Roofmaster
Rewards Points: 2,172
Why dont you buy a piece of clear white pine and make up a new drip to match the original? Not too hard if you have a power plane, and a router.
The Following User Says Thank You to jagans For This Useful Post:
phw86 (07-04-2013)
Old 07-04-2013, 11:21 PM   #7
Unfortunately all I have to work with is an old table saw :/ maybe I'll ask around and see if I can find some help.
Old 07-04-2013, 11:24 PM   #8
I suppose it's doable on the old table saw, id need a new blade. I would definitely need another pair of hands to do one single piece
Old 07-05-2013, 08:14 PM   #9
Lower the clapboard is gonna work just fine, thanks all who offered advice.
Old 07-05-2013, 10:18 PM   #10
Roofmaster
You can do it all on a table saw too.
Old 07-05-2013, 10:30 PM   #11
Yeah your right. However my dad decided he wants the PVC cap. I'll post the finished result.
Should installed drip edge cover fascia board? dilerin Roofing/Siding 12 11-04-2012 03:03 PM
Vented Drip Edge problem vadifey Roofing/Siding 5 08-29-2012 04:20 PM
Drip Edge over top of sand-asphalt roll at sloping edge Fun Value Roofing/Siding 0 04-08-2012 01:31 AM
Can I install a drip edge on this roof myself? housenewbie Roofing/Siding 1 01-25-2011 07:57 PM
new drip edge over existing gutters scheiman Roofing/Siding 1 06-05-2010 08:44 PM
