Figuring The Cost - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-04-2014, 10:30 PM   #1
Rewards Points: 109
figuring the cost
I just got an estimate that seems a little high to me. All I can figure is the labor to strip 3 layers is increasing the price. Also there is about 40' of step flashing that needs to be done , I imagine that is time consuming and may drive up the cost.
hitmehhh is offline   Reply With Quote
Old 04-04-2014, 10:57 PM   #2
Rewards Points: 744
I'm not seeing the question here....
Anyhow, yes, more layers to tear off and haul away = higher cost for you.
Seattle2k is offline   Reply With Quote
Old 04-04-2014, 11:38 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,984
In my neck of the woods, a typical tear off crew will charge about $800-1500 for a typical house
Note - typical is very vague. About like the op's post
The Following User Says Thank You to ddawg16 For This Useful Post:
roofermann (04-05-2014)
Old 04-05-2014, 07:13 AM   #4
ParagonEx's Avatar
Rewards Points: 150
Why does it seem high? Is the house steep? Lots of valuable landscaping?
Three layers always adds cost to the job and just like you wouldn't rather have to pay it, the roofers would rather not have to do it.
Three layers adds time for tearing off, cleaning up and costs more in dump fees.
ParagonEx is offline   Reply With Quote
Old 04-05-2014, 08:03 AM   #5
Rewards Points: 109
I was comparing it to the front roof we had done 12 years ago. I figured the cost could even be double after 10 years. The sq. footage is about the same but this is a garage roof and a birdwalk that also adds the labor of cutting back the siding for the new flashing.
Old 04-05-2014, 08:34 AM   #6
Rewards Points: 14,026
Three layers will take three times as long to strip, pick up, clean up and if they charge tipping fees at the dump that's three times the weight to pay for.
Shingles and nails have more then double in price in the last 10 years. There made from petroleum, has the price of gas gone down? Nope.
I'm sure labor sure has not gone down ether.
I used to charge by the square X the number of layers for tare off.
Not happy with the quote, get some more to compare.
Old 04-05-2014, 09:17 AM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,410
Or get a shingle rake and a dump truck...
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Gymschu (04-06-2014)
Old 04-05-2014, 09:21 AM   #8
Rewards Points: 109
I have no problem with paying for the job. I have another company coming to give an estimate. I just really like this company and I am willing to pay a little more for the peace of mind that the job is being done right. I just hope the price is in the ballpark.
Old 04-05-2014, 09:37 AM   #9
An old Tradesmen
Rewards Points: 7,832
Only way to know. is to get multiple estimates from contractors, and compare them by what they say they will do.
Old 04-05-2014, 10:03 AM   #10
Rewards Points: 154
I would like to comment but I don't even see that the actual quote and complete scope of work has been posted so I don't see much I could contribute.
eharri3 is offline   Reply With Quote
Old 04-05-2014, 10:30 AM   #11
Rewards Points: 109
Garage roof 14'x 30'. Birdwalk 2'x25'. strip 3 layers. Approx 40 stepflashing after cutting back cedar shakes to step flash. 10' ridge vent installed. 3 tab shingle installed/ice and water barrier / deck armor roof protection installed
Old 04-05-2014, 09:12 PM   #12
Rewards Points: 154
I will pull a couple more teeth and ask what the actual price was that you are so dissatisfied with.
Old 04-06-2014, 03:52 AM   #13
JOATMON
ddawg16's Avatar
Originally Posted by ErniesGutter View Post
Anytime you have more then one layer it will DRIVE the cost up Alot ...
Fact 1: all shingles below the top layer have cooked the lower shingles to a bridal crisp causing the tareoff to go VERY much slower.
Flashing is a must & yes it will cost more if it was not installed right the first time !
ErniesGutter
And.....lets not forget the wood damage that is most likely there....
People put on a new roof when it leaks.....if old roof is not removed....damaged wood stays....do this 3 times? Care to guess how much damaged wood is there?
Old 04-06-2014, 07:45 AM   #14
Rewards Points: 109
eharri3, I thought that price quotes were frowned upon on this website.
Old 04-06-2014, 07:57 AM   #15
They are, it was for our entertainment only, post at your own risk.
Cost to Drywall hang/finish...please read, good explanation Firehawk734 Remodeling 64 12-12-2014 04:15 PM
Cost of a small 2 story addition mattmean Building & Construction 15 08-09-2011 10:14 AM
Figuring this KwH cost??? deck hand Electrical 13 05-13-2008 08:52 AM
