Fiber Cement Siding - Nailing Butt Joints? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-22-2013, 01:12 PM   #1
Fiber Cement Siding - Nailing butt joints?
I finished an 8ft x 24ft wall this week in my off time. Looks wonderful execpt for some of the corners on the butt joints aren't tight against the house.
What nail or system do I use to make these tighter and even against the house?
I've been underside nailing them.
DukeLewis87 is offline   Reply With Quote
Old 06-22-2013, 01:15 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 4,624
....Trim....
MTN REMODEL LLC is offline   Reply With Quote
Old 06-22-2013, 01:24 PM   #3
kwikfishron's Avatar
Rewards Points: 194
You need to face nail the butt joints and where siding meets the corners, windows, etc. I'd use 7d ring shank siding nails for that.
kwikfishron is online now   Reply With Quote
Old 06-22-2013, 01:56 PM   #4
Thats what im using now execpt im nailing underneath the 1.25" overlay
7d hot dipped galvanized ring shank coil nails
Should I predrill and hand nail it for going threw the overlap+face?
Old 06-22-2013, 01:57 PM   #5
Originally Posted by MTN REMODEL LLC View Post
....Trim....
Ha. 90% of trim was on before I sided it...
Old 06-22-2013, 02:15 PM   #6
Gotcha...
Old 06-22-2013, 02:39 PM   #7
So should I predrill and hand nail threw 2 layers or just turn the depth a little on the nailer.
Old 06-22-2013, 05:22 PM   #8
Rewards Points: 194
You need to nail through both pieces about 3/4-1" up from the bottom edge. I hand nail it. You can per-drill if it you want but it's not necessary most of the time.
The Following User Says Thank You to kwikfishron For This Useful Post:
DukeLewis87 (06-22-2013)
Fiber Cement Vrs Vinyl DukeLewis87 Building & Construction 19 06-02-2013 12:46 PM
Fiber Cement Shake Siding around windows smithta3 Building & Construction 2 08-06-2012 10:47 AM
Question: Fiber Cement Shingle Siding Installation Greg D Building & Construction 2 09-06-2011 09:41 PM
Surface bond cement and fiber cement shingle Harpoon Building & Construction 2 01-19-2011 06:40 PM
caulking butt joints on siding downunder Building & Construction 7 11-13-2008 04:56 AM
