#1 |
felt paper and rain
Hi - i'm getting my roof redone but we discovered the front porch was completely rotted. It took a couple of days to tear down the porch and rebuild. The roof above the porch is felted with #30 paper and now it's raining. Is that really ok to have just the felt on in the rain for the next couple of days. It kind of makes me nervous.
#2 |
Framing Contractor
felt paper and rain
Ideally, you should only tear off what you can cover with shingles in the same day. Felt paper is very prone to ripping and coming loosed during heavy winds. I hope you didn't use a slap stapler on it.
#3 |
felt paper and rain
its called a tarp
#4 |
KemoSabe
felt paper and rain
Felt will only hold out water for a short period of time. As felt is wetted, it will expand and begin to wick water through.
It's actually a neat process, but not great for long term water hold out.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks. |
#5 |
felt paper and rain
I'm not the one puting the roof on. I hired a roofer and he insisted this is fine, but we're expecting more rain before he finishes next week. I can't go up on the roof and tarp it sothat's why i'm asking what i should do?
#6 |
Residential Roofer
felt paper and rain
Assuming it's installed properly, 30# felt can set exposed to the weather for a couple to a few weeks with out any problem.
God Family Country Work Play
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#7 |
felt paper and rain
I just went out to look at it after last night's rain and it's kind of rippled. Will that straighten back out when it dries completely or should i make him tear it off. I'm replacing an old roof that's all rippled and i don't want another. (not the same roofer)
#8 | |
Residential Roofer
felt paper and rainQuote:
(Time as in an hour or so to dry out, not days or weeks)
#9 |
felt paper and rain
Felt paper can wrinkle when wet. IMO you do not rip what you cannot roof. If for some reason you cant finish what you've ripped it should be tarped.
#10 | |
KemoSabe
Contrary to popular belief, felt paper, or tar paper as most folks call it, is not waterproof. More accurately stated, it is moisture resistant at best. Whether or not that is a pro or con is a long argued matter.
#11 |
felt paper and rain
Thanks - i talked tom y roofer earlier. He does not plan to leave that paper on. He will rip off and replace with new paper when he does the roof this week.
#12 |
Residential Roofer
felt paper and rain
Kewl, I'm glad he put your worries to rest.
#13 |
felt paper and rain
I'm not a roofer, just a homeowner, so bear with me. When you put down shingles, you work from the bottom up, so how does this work? Or are you talking more side-to-side?
#14 |
Roofmaster
felt paper and rain
Boy, you move around a lot. You work from the eaves to the ridge usually from left to right. The directions are on every bundle of shingles you buy, and on the manufacturers web site. Pay strict attention to where you nail. Most newbies nail too high and miss the headlap, possibly resulting in tab lifting and blow off. Use six nail method per shingle with three tabs.
" A lot of men build things, and a lot of things fall down " |
| Display Modes | |
| Rain gets underneath gutter | Heimwerker | Roofing/Siding | 8 | 12-28-2011 01:59 AM |
| Sheet rock paper came off | JEDI RAIN | Drywall & Plaster | 4 | 03-09-2011 10:56 AM |
| Window Flashing with Felt Siding | user284 | Remodeling | 1 | 09-12-2010 11:32 PM |
| Tar paper ok in rain? | diyintexas | Roofing/Siding | 5 | 09-24-2009 12:19 AM |
| roof not on yet and a whole lotta rain | THEBIGPUNN | Building & Construction | 10 | 11-21-2005 07:15 PM |
