Felt Paper First Then Drip Edge? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-13-2012, 11:39 AM   #1
felt paper first then drip edge?
I am trying to find out if you should put the felt paper down first then drip edge, or the drip edge first then felt paper for a asphault roof in florida? Thanks
cth61 is offline   Reply With Quote
Old 03-13-2012, 11:48 AM   #2
Rewards Points: 13,270
I lay the paper over the drip edge.
I look at it this way, would you start laying the shingles from the top of the roof and work your way down?
You would want water to run down the paper and over the drip cap not be able to get under it.
cth61 (03-13-2012)
Old 03-13-2012, 12:40 PM   #3
Doing This Way Too Long
Rewards Points: 532
Roofing 101-Think Like Water
OldNBroken is offline   Reply With Quote
The Following 2 Users Say Thank You to OldNBroken For This Useful Post:
Roofmaster417 (03-13-2012), Windows on Wash (03-14-2012)
Old 03-13-2012, 01:35 PM   #4
RFN-4A-LVN
Roofmaster417's Avatar
Under the drip edge on the rake and over the drip edge on the gutterline.
With you being in Florida the FBC requires the starter shingles (And lap) to be sealed directly to the drip edge.(Bull)
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
silicone rake drip edge to shingles ? Arky217 Roofing/Siding 6 02-17-2012 08:11 PM
roof/wall drip edge interface? wombosi Building & Construction 1 05-15-2011 06:42 PM
drip edge vs. asphalt felt amakarevic Roofing/Siding 1 04-14-2011 10:58 PM
Gutters leaking with drip edge. Help! hansmike Roofing/Siding 6 10-10-2010 07:02 AM
Best way to waterproof fascia when roof lacks a drip edge? Studly Roofing/Siding 4 10-07-2009 11:49 AM
