Felt Or Not? Zip OSB - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-25-2011, 06:22 PM   #1
Rewards Points: 31
Felt or not? Zip OSB
We are presently constructing an addition which includes an entirely new roof design. We decided to use the Zip roof sheathing system which supposedly does not require felt underlayment below the shingles which will most likely be a 40 yr arch. (Maybe Timberline)
Ice/Water membrane will be applied at all edges and valleys but I am looking for some opinions on whether or not we need to bother with felt. Thanks.
Rustygaff is offline   Reply With Quote
Old 07-25-2011, 06:29 PM   #2
Framing Contractor
Rewards Points: 126
Not sure what all the roofing manufacturers have to say, but using Zip eliminates the need for felt. I have been trying to talk a couple of Contractors into trying it, but so far no luck.
sixeightten is offline   Reply With Quote
Old 07-25-2011, 06:31 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Since the shingles aren't waterproof, but only water ressistant, I'd felt it. You could do that with shingles in the 50's-60's, even the 70's. I wouldn't try it with today's product.
tinner666 is offline   Reply With Quote
Old 07-25-2011, 06:36 PM   #4
Pro Slate Roofer
tinner666's Avatar
I see we replied at the same time. Basically the same answer too. The shingle manufacturers say the zip system will keep the water out. If the shingles were waterproof, regular OSB would be OK by them.
Old 07-25-2011, 07:19 PM   #5
kwikfishron's Avatar
Rewards Points: 1,022
Felt is time tested and cheap to boot. I’ll reserve my judgment on coated osb for another ten years or so., been burned by sales reps and marketing before. Remember LP?
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
MJW (07-26-2011)
Old 07-26-2011, 06:07 AM   #6
Residential Roofer
Slyfox's Avatar
Water won't go through the shingles but it will seep in through the joints
(even when dutch lapped) and up under the tabbed portion in wind driven situations.
Zip - not time tested.
Synthetic underlayment - not time tested.
Felt - time tested and proven to work.
I have tried synthetics and all I seen and read/hear about them, most are good.
I never worked with Zip yet.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 07-26-2011, 06:59 AM   #7
Rewards Points: 31
Thanks guys. You reenforced what I was thinking...............felt is cheap and time tested.
Old 07-26-2011, 12:42 PM   #8
Framing Contractor
Rewards Points: 126
Why did you decide to use Zip if you were going to felt it anyway?
Old 07-26-2011, 08:24 PM   #9
Rewards Points: 31
We are building in a coastal area. Wanted T&G edges and some additional water repelling qualities.
Off the beaten track...............looking for a decent but not overpriced vinyl deck rail system. Any help here would be appreciated. Thanks.
Old 07-28-2011, 11:32 AM   #10
Grumpy's Avatar
Rewards Points: 552
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
The only job we've done over zip, we installed felt. I'm not going to rely on unproven new technology and besides osb sucks anyways.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 07-30-2011, 07:34 AM   #11
Tom Struble's Avatar
Rewards Points: 2,002
these panels are more plastic than wood,but just relying on the sealing power of the seam tape instead of shingled felt seems counter-intuitive
Tom Struble is offline   Reply With Quote
Using Felt with Cedar Shakes freddmc Roofing/Siding 32 10-08-2011 11:26 AM
Adhesive window flashing and 30# felt Numb Building & Construction 4 05-23-2011 11:04 PM
Window Flashing with Felt Siding user284 Remodeling 1 09-12-2010 10:32 PM
Felt for Reinke Alum Shakes SCDome Roofing/Siding 1 09-26-2009 01:53 PM
How do I attach the 15# roofing felt to the subfloor? rncopper Flooring 8 06-23-2008 09:17 PM
