Felt Is Not Perfectly Flat! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-22-2006, 04:57 PM   #1
The Flying Toolbox
handypilot's Avatar
Felt is not perfectly flat!
I decided that I was going to tackle roofing my 2.5 car garage by myself, over a 5 day period. Well, after ripping off two layers of asphalt shingles, I started rolling out 30# felt. It's a 8/12 pitch and the roll wouldn't stay in place as I rolled it out and tried to secure it. I tried to get it as flat and as straight as possible while using 1/2 staples to secure it temporarily. It looked pretty good, and I put several staples in to prevent ripping the paper as I walked on it. After it was all in place, I went back and secured it with plasti-cap nails (1 1/4"). I thought I got the paper flat, but the next day I came out and there were a bunch of ripples in it.
Will this cause a problem with the shingles lying flat?
Again, I have....
  • #30 felt
  • Architectural 30 year shingles
  • 8/12 pitch for a detached garage
I really don't want to redo the felt because I have to complete the project by myself!
handypilot is offline   Reply With Quote
Old 09-22-2006, 06:32 PM   #2
Commercial Roofing
AaronB's Avatar
If it looked perfectly flat when you installed it, then 30# should dry and flatten out. This is why I like 30#
If it does not, or rips or slides due to the elements, you may have to cut and patch the wrinkles, or replace it all. I see this moreso with 15#, and doubt it should be a problem.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-26-2006, 01:13 PM   #3
Rewards Points: 150
X2, it should flatten as it dries out!
harleysilo is offline   Reply With Quote
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 06:08 AM
Flat Roof Replacement Quote Questions rocketmahn Roofing/Siding 1 01-02-2006 07:01 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
