-   -   Fascia Replacement (http://www.diychatroom.com/f9/fascia-replacement-44477/)
John Jay 05-14-2009 09:22 AM
Fascia Replacement
My question is, can I replace my fascia myself, I have done flooring, siding, plumbing etc. I have a few boards that need replaced and I am concerned about the flashing and How to install new with out causing damage to the shingles? Also when the fascia is removed this will not affect the rafters due to the weight correct? Any advice would be appreciated.:thumbup: John
Ron6519 05-14-2009 10:24 AM
The only difficulty with fascia is how high it is off the ground. As long as you take it off and install it parallel to the roof line, you shouldn't have a problem with either the shingles or the drip edge.
Removing the fascia shouldn't effect the rafters holding up the roof. They're basically just caps to keep the rafter bays closed up.
Ron
Dale Chomechko 05-18-2009 12:18 PM
Don't try this yourself, it usually takes 2 people & both need to be familiar with working on high places.
Quite often we use the old fascia for a template to cut the new one.
Not usually a difficult job unless you shingles are nailed into it
Dale Chomechko
DC Roofing Inc
