Fascia Material - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-16-2009, 07:39 PM   #1
Fascia Material
Is OSB sheathing suitable to use for fascia?
kz6k9q is offline   Reply With Quote
Old 04-16-2009, 08:18 PM   #2
Not at all.
Are you considering doing it, or some, "CON-tractor?"
#2 pine or cedar are the most commonly used wood fascia materials used.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-16-2009, 10:25 PM   #3
Kitchen remodel Guru
A.W. Davis's Avatar
Rough sawn pre-primed pine and you are golden!
A.W. Davis is offline   Reply With Quote
Old 04-16-2009, 10:27 PM   #4
Only if you want to replace it when it falls apart
Old 04-16-2009, 11:38 PM   #5
You are referring to the OP's suggestion of considering using OSB, not referring to the pine options, right!
Ed
Old 04-17-2009, 06:13 AM   #6
Fascia
Thanks for the info everyone. I was leaning towards the pine, but since I had plenty of sheathing on hand I was considering it. Not anymore.
Old 04-17-2009, 09:00 PM   #7
I actually use 2x lumber for fascia
No problems securing my gutters, or anything else
Old 04-18-2009, 05:25 PM   #8
Tom Struble's Avatar
Rewards Points: 2,002
good idea Dave
Tom Struble is offline   Reply With Quote
Old 04-18-2009, 10:57 PM   #9
Originally Posted by tomstruble View Post
good idea Dave
Only if it is New Construction.
If this is an existing roof, the additional width will not align with the existing Gutter Apron sheet metal drip edge flashings and the extension of the current shingle overhang.
Ed
12" Fascia Board Maralind Roofing/Siding 6 01-26-2009 05:26 PM
replacing fascia board joefromcal Roofing/Siding 12 08-18-2008 06:33 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
