Fascia Boards - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-11-2012, 10:43 AM   #1
Question
Fascia boards
Been trying to search for this answer but to no avail.
Getting ready to replace all my fascia boards (and soffit too) and I have a question. Do I need to angle the top of the fascia board to match the pitch of the roof? My old fascia boards have the angle, but when replacing is this necessary?
geocheves is offline   Reply With Quote
Old 01-11-2012, 10:54 AM   #2
kwikfishron's Avatar
Rewards Points: 176
No, itís not necessary.
I run fascia so the outer edge of the fascia planes in with the top of the sheathing. Along with the drip edge this helps protect the sheathings edge.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
mae-ling (01-11-2012)
Old 01-11-2012, 11:08 AM   #3
Thanks. I was leaning that way but just wanted (read needed) to hear someone else agree with my thinking!
Old 01-11-2012, 12:09 PM   #4
Doing This Way Too Long
Rewards Points: 532
'zackly
OldNBroken is offline   Reply With Quote
Old 01-11-2012, 06:00 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,786
+2
That is the way to go.
Pulled a roof off the other day where the home builder didn't want to spend the extra money to sheet the whole roof. There was about and 8" gap between the sheathing and the fascia board around the entire perimeter...
How do I replace my fascia boards? schermd Carpentry 16 03-24-2011 06:46 PM
Original Fascia boards need to be replaced brickhaus Roofing/Siding 3 08-25-2010 11:10 AM
Cutting my 2 x 8 fascia boards joefromcal Roofing/Siding 4 09-09-2008 10:08 AM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 08:34 PM
Are fascia boards rough carpentry? Paul58 Building & Construction 10 04-19-2006 11:18 PM
