Fascia Board For 6 Inch Gutter - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-18-2010, 09:32 AM   #1
fascia board for 6 inch gutter
We are thinking of upgrading our gutters from a 5" to 6" but are wondering do we need a 1x8 trim board versus the existing 1x6? We live in Michigan where ice and snow are heavy. Seems there is conflicting info out there regarding this. Thanks.
ToroMich is offline   Reply With Quote
Old 07-30-2010, 11:23 PM   #2
Registered User
Rewards Points: 5,516
If the rafter tails are under-sized for the over-hang loads, use 2x6, or 1x8. I see a small problem with the 1x8 being lower than the soffit which could interfere with the intake venting, if located close to the fascia board- where it should be for the best air pressure away from the rain and snow near the house wall.
http://www.rd.com/how-to-seal-attic-...icle18158.html
http://bct.nrc.umass.edu/index.php/p...ting-ice-dams/
http://www.cmhc-schl.gc.ca/en/co/mah...gemare_001.cfm
Be safe, Gary
Old 07-31-2010, 04:22 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
If the practice in MI is to set the gutters low enough so sliding snow shoots over them (it's not here in KY), then no, a 1x6 fascia is too small. It would also be too small if there were very long runs involved.
The fascia should be sized to the rafter tales. Adding downspouts is one option to get more flow through 5" gutters.
seeyou is offline   Reply With Quote
Carrier furnace control board - OEM or ICM ? anku HVAC 13 10-12-2012 10:50 PM
another shower wall question foothill Remodeling 5 07-11-2009 05:11 PM
Fascia Board what to do? superstick Roofing/Siding 6 10-18-2008 07:19 PM
Water Heater 1/2 inch pipes tke402 Plumbing 7 10-04-2008 11:19 AM
Fascia Board yyang85 Roofing/Siding 8 08-27-2008 10:20 PM
