Fascia Board - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-25-2008, 03:46 PM   #1
Fascia Board
We are replacing our gutter. The current gutter does not have the fascia board attached to. We would like to know if it is a good idea to add new fascia board before we put on the new gutter. Or it is OK to put on the new gutter without the fascia board as it has been for the last twenty years.
Thanks!
yyang85 is offline   Reply With Quote
Old 08-25-2008, 04:59 PM   #2
Doing This Way Too Long
Rewards Points: 532
Can't really tell without seeing it but...
If it ain't broke...
OldNBroken is offline   Reply With Quote
Old 08-25-2008, 05:18 PM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
by adding the fascia will you have room for the shingles to hang over the top with no problems with water getting behind. and will all windows and doors open with out hitting the bottom of the fascia? . These are things that come to mind, with out seeing the situation. BOB
Old 08-25-2008, 05:49 PM   #4
What they are saying is, please post some photos so that we could more accurately assess the situation.
Ed
Ed the Roofer is offline   Reply With Quote
Old 08-26-2008, 09:17 PM   #5
Pictures of our current gutter
Here are some of the pictures of our current gutter.
Our question is do we really need to add fascia board after we take down the old gutter and before we put on the new gutter?
Thanks again for your comments!!
Fascia Board-20080803-021.jpg   Fascia Board-20080803-022.jpg   Fascia Board-20080803-018.jpg
Last edited by yyang85; 08-26-2008 at 09:21 PM. Reason: make the question more clear
Old 08-26-2008, 09:32 PM   #6
buletbob's Avatar
I don't know if the roof shingles are going to overhang the new fascia and gutter. The gutter would lay nice with a backer. If cost is an issue go with a heavier gutter .032 gauge and install with screw in metal hangers. your rafters are 24" on centers, so the spacing is no problem. BOB
Old 08-26-2008, 10:47 PM   #7
Since the shingles are already in place, just addding the fascia board on now would possibly cause problems with the eave edge overhang, even if you also installed a Gutter Apron Drip Edge metal flashing tucked under the shingles and tried to get it to reach into the gutter trough.
I would foresee water entry potentioal problems behind the Gutter Apron, so leave well enough alone.
Ed
Old 08-27-2008, 10:11 PM   #8
So....
Thanks Guys.
So is it OK to replace the gutter without adding the fascia board?
Old 08-27-2008, 10:20 PM   #9
Rewards Points: 532
Your roof design is meant to have exposed tails and no facia. As long as the tails havent sucked too much water and started rotting, I wouldn't change the original design.
replacing fascia board joefromcal Roofing/Siding 12 08-18-2008 06:33 PM
What type of wood is used to replace soffit and fascia board? creamaster Carpentry 6 07-16-2008 01:20 PM
How to remove drip edge to get to replace fascia board mr-hobo Roofing/Siding 2 07-14-2008 09:28 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
