Fascia: 2x6 Or 1x6? Cedar Or Spruce? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-05-2009, 06:38 PM   #1
Fascia: 2x6 or 1x6? cedar or spruce?
Hello.
We are getting a new roof and new gutters. Current gutters are a PITA because they always clog. They were installed w/o fascia board.
We want fascia board put up so we can have the gutters be more sloped for better water movement.
Gutter guy quoted 1x6 spruce, which will be primed and painted on front and back. Roofer guy will be quoting 2x6 cedar, which will also be primed and painted. Roofer guy said that 1x6 has some potential issues w/waviness or something (don't recall what exactly he said).
Not being technical, which is the appropriate size--1x6 or 2x6? And which is the better wood--spruce or cedar--or is either wood okay?
background: house is 21 years old, painted cedar, in WA.
TIA for any input.
Dodah is offline   Reply With Quote
Old 06-05-2009, 07:18 PM   #2
Most common is 1x material
I use 2x - not prone to warp or bow as much as the 1x
I like to be able to fasten/nail securely along the fascia board & know it will hold
Old 06-05-2009, 07:30 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Hi,
Standard installation practice is for the fascia boards to be are attached (nailed) directly to the rafter tails ends. The rafters are 2x stock. Their ends are generally not even and aligned. There are several reasons for this. One in particular is from cupping.
Thus, when installing 1x trim boards (which are usually pre-primed pine), the 3/4" (1x) thick boards (fascia) will contour to the "profiles" of the rafter tails, and their positions. Again, because these tend to vary and are not the same (not all aligned), so the fascia will be installed with a "wavy" appearance.
Generally, we install 1x stock fascia with a string line stretched tight and straight to the measurement needed. We also use cedar shims between the rafter tails and the 1 x fascia boards, to be able to set and nail the fascia - straight and aligned.
There are other methods to straightening the fascia out, one of which is by using thicker 2x fascia stock (such as the 2x Cedar being suggested to you), or, by creating a 2x "sub-fascia", that the 1x stock is attached to. The point is that thicker boards are less likely to follow irregular contours of what they are attached to (nailed to).
Another advantage of Cedar, over pine, is it' natural resistance to rot.
Out of the two offers, I'd suggest going with the Cedar. Hopefully the roofer will offer it painted and sealed with the installation.
Personally, if your fascias are going to be white, I'd strongly suggest using a white STAIN over paint. That way, as the areas weather and age, you will not have to scrape down peeling paint and "re-paint" them. Stain will simply fade, and only require minor cleaning, or a pressure washing, and a new application of stain.
- Build Well -
Old 06-05-2009, 08:05 PM   #4
You guys are great!
And thanks for the suggestion re white. We were going to paint white so would not have thought about the long-term ramifications.
Old 06-05-2009, 08:11 PM   #5
Okay, after I wrote my last reply, DH had a question about AtlanticWConst's point re the painting/staining.
We were going to get the boards primed first. Can stain be applied on top of primer? or should we ask the contractor to not prime first. (Not sure if the boards already come primed in which case maybe asking for the primer to not be done would maybe create more problem than it's worth.)
And you mention sealing--would that be needed if the boards are primed and painted instead of stained, or is sealing needed no matter what?
What brand of white stain and sealant do you use?
Old 06-05-2009, 08:33 PM   #6
Tell him not to prime the boards. Since he's offering to "apply" a "protective liquid coating"....ask him to apply a white stain. Stain can only be applied to "untreated stock" (unpainted stock).
As far as what brand is best. We (my business) has a painting division, but I have, litttle to nothing, to do with that. You might try a search on this site regarding that question. Look in the Painting Section.
Best of luck.
- Build Well -
Old 06-06-2009, 06:07 AM   #7
the Musigician
DangerMouse's Avatar
i don't mean to be stupid, it comes naturally to me, so excuse this question.... but what the heck is DH??? dumb husband?
DM
Old 06-06-2009, 05:55 PM   #8
Dear Husband and DW is Dear Wife.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-06-2009, 06:03 PM   #9
the Musigician
oh, ok.... tnkx
and here i thought DW was Dora Winifred..... i think maybe i watched too many cartoons with the kids.... lol
DM
Old 06-06-2009, 06:19 PM   #10
I was thinkin Dumb instead of Dear
Old 06-07-2009, 08:56 AM   #11
MJW
Are you talking about your own home when you say "I use" or "I do this"?
Anyways, 2x's are most common used here now. Used to be 1x's, but they didn't hold up real well because people wouldn't keep up on the painting. Why mess with wood? Why not use 2x's and cover with steel fascias? Is that not common where you are located?
It really cleans up a house, unless you are going for the wood look....then my suggestion would be stained cedar.
MJW is offline   Reply With Quote
Old 06-07-2009, 08:50 PM   #12
I've yet to see any builders around here using anything but 3/4" fascia
cedar deck looks like crap silky Painting 16 05-02-2009 10:42 PM
12" Fascia Board Maralind Roofing/Siding 6 01-26-2009 05:26 PM
Spruce vs Cedar Wildie Building & Construction 12 11-12-2008 08:55 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
