Fanfold Or Tyvek - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-08-2014, 05:55 PM   #1
Fanfold or tyvek
What is the best thing to do under vinyl sideing? My house has o insulation. It has wood lap sideing under the slate asbestos sideing and some one has removed it from the gable end above the porch. The house is small about 27x32 with a 12/12 roof with one room up stairs. Each end has a 26 x 60 window in the gable end. I have a gray metal roof. For now i would like to side the end were slate is removed would it look good to go with gray sideing above the porch and white below on the house. I have ask alot of my friends most all of them have side more than one house but no one seems to now what would look good.
Mo Guy is offline   Reply With Quote
Old 08-08-2014, 08:23 PM   #2
Rewards Points: 652
I woul probably drill holes in each stud bay above and below any firestops, and blow in insulation. Last I checked, fanfold is r4. Blown insulation isn't perfect, as it may settle in the wall over time.
PatChap is offline   Reply With Quote
Old 08-09-2014, 09:25 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,274
Insulated the stud walls once you have the cladding off.
Wrap the home in real, rigid foam (depth depends on wall construction and location), and then put on the housewrap and new siding.
Old 08-09-2014, 04:37 PM   #4
For right now i am only doing the gable end second story and the plaster is bad so maybe this winter i will strip the plaster off insulate and put up new sheetrock but the main leavel i may blow in because plaster is steal good.
Old 08-12-2014, 03:35 PM   #5
Fanfold is around R1. I like the suggestions above; insulate, new sheathing and then put up your house wrap either Tyvek or Blueskin.
Forrest77 is offline   Reply With Quote
How To Seal Tyvek Terminations At Wood And Composite Trim? gunner666 Roofing/Siding 5 08-06-2014 01:52 AM
Tyvek Confusion drjay9051 Roofing/Siding 10 09-20-2013 11:45 AM
tyvek question roughsawn General DIY Discussions 11 03-03-2011 08:00 PM
Stucco contractor cut up all my Tyvek! What to do? Gatorback Building & Construction 9 10-20-2008 05:43 AM
Tyvek application in crawlspace libwes Building & Construction 3 03-27-2008 11:45 AM
