Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-19-2010, 05:55 AM   #1
faced or unfaced insulation for flat roof?
I have gutted my 3rd floor and have reframed it now I need to add some insulation. Any ideas on which kind of insulation would work best? I plan on putting up 1/2 drywall. Also I live in the NE so cold winters and hot summers.
crazychef55 is offline   Reply With Quote
Old 01-19-2010, 08:08 AM   #2
Xtreme DIY'r
What size are the joists , how much room for insulation ?
Old 01-19-2010, 03:04 PM   #3
Moderator
According to this, with a 191 zip, you need R-38 in the attic: http://www.ornl.gov/cgi-bin/cgiwrap?...le/ins_fact.pl
The best would be spray closed cell foam, at about R-6 per inch: http://www.henry.com/fileadmin/pdf/H...l_Brochure.pdf
A special glass batt insulation, R-38C is used with 2x10 roof rafters. (Or furr down the existing rafters).
Rather than glass batt, I would use : http://www.buildinggreen.com/auth/ar...&printable=yes
You could also use cellulose and rigid foam board on the rafters to get required R-value and a vapor retarder in one.
You may/not require a vapor retarder because some B.D. state you need 12” of air space above the insulation with one. (Typical attic) http://www.buildingscience.com/docum...ecommendations
You might be able to use vapor barrier paint, ask your local B.D.: http://www.ornl.gov/sci/roofs+walls/...on/ins_18.html
Is the roof vented?
Be safe, Gary
Clothes taking longer to dry?
Old 01-20-2010, 09:11 AM   #4
The joists are 8" and I have about 11" of space to the end of the studs that will be used for the drywall.
Insulation - Faced vs. Unfaced + Plastic Sheet WaldenL Building & Construction 4 07-06-2011 12:41 PM
Blown Insulation - Flat roof AndrewF Roofing 1 12-31-2009 07:41 PM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 01:06 PM
Cape Cod Roof Insulation remernorth Building & Construction 5 09-06-2009 08:22 PM
